Newb repairer here..monitor question
kingtreelo
18 (100%)
1,512CR
So, 3 machines nabbed, one works perfect, one doesnt turn on, and one has a monitor like this...
I'm not comfortable working inside the monitor part of a machine and if this isnt an easy fix would much rather pay someone, is this an easy fix, the screen looks fine it is just off to the right hand side a fair bit
Also, if its not an easy fix, does anyone know of anybody in the Northwest who can fix these?
Any at arcade club for example who wouldnt mind a foreigner?
tb2000
3,218CR
I'm assuming this isn't just a matter of horizontal position being adjusted? Although with the slight curve of the image at the top of the screen it looks like the horizontal sync or position needs a bit of adjustment. What's it got in it? Hantarex Polo or something?
kingtreelo
18 (100%)
1,512CR
im not sure, i havent got into it yet, have a few issues as dont have the keys, im going to guess its whatever was in them originally as these have been in storage for years and years
tb2000
3,218CR
If it's a UK build it's likely got a Hanty of some sort, possibly a Polo, maybe something older like a MTC9000. Although it could also have a WG K7000 in it or something. If you can somehow get the coin door open you might be lucky enough to find the monitor remote adjustment board in there.
big10p
Coins detected in pocket!
5,640CR
Just to add, the remote board was behind the bezel glass on a Leisure 2000 cab I once fixed. It was a different model, though.
gunblade
22 (100%)
8,760CR
i remember having problems with this game on certain chassis, something with the sync signal but i don't remember exactly what it was - twas a very long time ago
i think it had problems on kortek or k7000, can't remember which
ExZX
26 (100%)
1,294CR
Have you opened the cabs up yet?
If so have you metered the PSUs?
Try a different board in the cab as the board may be the issue.
If you have a 60 in1 or 19 in 1 then try that in test mode.
4,678CR
You might as well get used to altering the controls for width, height, sync, brightness and contrast if you put different PCB's in as they have different video levels and usually have to adjust many pots to setup
