newbie
Damaikon
0CR
Hi people just a post to say hello and to ask if any one repairs pcb as I have a 1980 Taito space invader game board not working
,Best regards Rob
7,229CR
Welcome to ukvac robin , there is a frw on here who repair. Have you checked voltages , removed and cleaned all socketed chips ?? Always check these first.
Also is it playing blind or not firing up at all ?? Maybe some pics would help.
Dave.TheDaddy2020-03-01 20:28:32
Damaikon
0CR
hi Dave thanks for the info,it does fire up with lines across the screen, have check and re-seated all removable chips but still the same
qjuk
51 (98%)
2,079CR
Hi Rob,
Welcome to the forum
As Dave said, check voltage to the board if you’ve not done already.
VectorGlow has previously repaired a few of my boards in the past so you can always drop him a PM to inquire about repairing yours.
Damaikon
0CR
ok thanks for info,I,m going to check supply voltage tomorrow then take it form there,I have put afew coins through but no joy Dave
Damaikon
0CR
Hi people
i've checked all the voltages on G and T connectors and supply all seems ok, there are 4 push pins at the back of the money draw but not sure what for???.
i also have replaced 47ohm resistor on the monitor supply board as it did'nt look healthy so now when i boot up the white lines are now straight,is there a way i could put a composite video signal to see if all's well with the screen?
any help much appreciated
rob
Damaikon
0CR
ok i've managed to locate pin-outs for composite video and have attach a B/W cctv camera and all's good with the screen
so any help with what next,there are some legs on the green 104k HEC bottom board broke off on one side could that be an issue
cheers for the help people
