Nichibutsu Crazy Climber
grobda
1,061CR
I agreed to have a look at this after some talk of it suiciding and probably needing an EPROM swap.
As the board was untested and the logic looked to be exclusively fujitsu I wasn't expecting much.
So built a basic harness and;
Not suicided then
... is it a battery backed CPU or a custom CPU with a ROM cache? I'd suspect the latter as that would have to be a pretty hardy battery, but I've witnessed stranger things
First problem;
Missing resistor array RM2. This is a pull-up array for player one inputs. I replaced this with one from a scrap board and inputs tested OK.
Second problem was audio. PCB booted up to a long beep. This went away during gameplay but returned at game over. The AY-3-8910 soundchip was socketed so I swapped it out with an equivalent YM2149F. This cured the problem.
Easy fix for a unique game. Being shat on by a seagull is genuinely unpleasant.
