Nichibutsu moon base
bones
1,628CR
Hi,I've just had a look at a table top version of this(pretty mint) for someone. Not seen this one before but the 3stack PCBs look very much like the taito version.
Anyway the monitor side looks OK it shows a decreasing white square when I power the machine down. The issue is that there's no 5volt on the PCBs,I found that on the ram board a dead short across all the tantalum bead capacitors(similar to the taito fault),but unlike the taito version which blows the 12volt fuse this PSU is just a board and I couldn't see any fuses on it. I found a 10amp and 2amp near the s1 coin mech,both are OK. Can anyone point me in the right direction on this one, I assume that the tantalum will need replacing, would I be looking for a fuse or did this version not have them? Also when this tantalum cap goes does it do any damage elsewhere? Any thoughts would be much appreciated
