ninja kid?
jengineer
49 (100%)
1,205CR
I have a Ninja Kid pcb made by UPL
the pcb is dead, nothing whatsoever, its like the jamma edge connector is not plugged in
so I'm thinking is it non jamma? and the board isn't getting any voltage due to it needing the correct adapter?
looking on crazy kong there is a pinout for ninja kid but its a funny pinout for 3player or 4player and its a 15 pin and 5/3 pin?
any ideas? or is my pcb just dead/faulty
*edit* just realised its Ninja Kid II
jengineer2015-04-09 21:01:35
AnDyC
529CR
Its jamma with m2 header as the video out
Code:
Ninja Kids    Pinout = JAMMA
  3P.Connector                      4P.Connector
  1   Coin 3                        1   Coin 4
  2   3P.Start                      2   4P.Start
  3   3P.Left                       3   4P.Left
  4   3P.Right                      4   4P.Right
  5   3P.Up                         5   4P.Up
  6   3P.Down                       6   4P.Down
  7   3P.Attack                     7   4P.Attack
  8   3P.Jump                       8   4P.Jump
  9                                 9
 10                                10
 11   Service                      11
 12   Counter 3                    12   Counter 4
 13   Lockout 3                    13   Lockout 4
 14   GND                          14   GND
 15   GND                          15   GND
M2 Connector                     S Connector
  1   Red                          1   Sound *
  2   Green                        2   Sound -
  3   Blue                         3
  4   Sync
  5   GND
AnDyC2015-03-20 10:25:19
favouredson
Super Star
1,260CR
MAME has Ninja Kid (Ninjakun Majou no Bouken) by UPL as released in 1984 which would make it pre-JAMMA.
The above diagram appears to be for The Ninja Kids by Taito from 1990.
jengineer
49 (100%)
1,205CR
just realised its Ninja Kid II which is jamma
pictures added to first post
any ideas? its completely dead, suicide battery?
jengineer2015-04-09 21:09:17
favouredson
Super Star
1,260CR
There might be something up with the metal box; encrypted CPU??
But there is definitely a missing 5MHz crystal on the bottom board.
jengineer
49 (100%)
1,205CR
ok cheers, its all a bit beyond me
cmonkey
1,659CR
Ninja Kid II uses a standard Z80 for the main cpu, so you can rule out suicide.
It uses an encrypted Z80 (NEC MC8123) for the audio CPU which contains a battery which may have died, but that will just result in no audio in the game, if it has died, once you get the board itself to boot. A dead audio CPU won't be preventing the board from booting however.
Is the crystal putting out a signal? If so, is that signal hitting pin 6 of the main CPU?
favouredson
Super Star
1,260CR
I just checked the MAME driver and it states that the sound CPU is encrypted (and runs at 5MHz).
Usually a non-working sound CPU would still allow the game to run but you never know.
The main CPU runs at 6MHz so I would assume that its clock is provided by the 12MHz crystal on the top board.
favouredson
Super Star
1,260CR
I just tried to post that last bit too quickly and got this message.
Error: Message Not Posted
Spamming is not permitted!
You have exceeded the number of posts permitted in the time span.
Please try again later.
5,653CR
Hello,
UPL did Atomic Robot Kid too right? I know that has an encrypted z80 and I believe the game won't run at all if it has suicided.
favouredson
Super Star
1,260CR
The MAME driver also states that the sound ROM has been decrypted.
MAME said:
The sound CPU in Ninja Kid II is a Sega MC8123 encrypted Z80. In some sets, the
ROM is replaced with a double-sized decrypted version. They are presumably
bootlegs but this isn't known for sure.
For Ninja Kid II: On Nov 15, 2008 a fully decrypted sound rom was created by
www.segaresurrection.com It allows you to replace the NEC MC8123 and encrypted
sound rom with a standard Z80B and the newly decrypted sound without any other
mods to the Z80 & sound rom as required by the other "double-sized" version."
cmonkey
1,659CR
According to MAME driver Atomic Robo-kid doesn't use either an encrypted main CPU or an encrypted sound CPU.
I can't see how the lack of a running sound CPU (and it's definitely not running as there's no crystal for it) would stop the board from booting as the only communication method between the main CPU and the sound CPU is a one-way sound latch from main CPU to sound CPU. Not impossible, but improbably, IMHO.
