Nintendo Playchoice 10 controls problem
Body pop
24 (100%)
1,266CR
Thanks for the reply
Yes an actual pc 10
It’s different than others I’ve seen. but yes
There’s a small board in back ,near the monitors .
Is that the inverter board ?
Purity
The Oracle
2,999CR
I'd agree with Phil. It looks like an inverter issue
Inverter looks like this:
Purity2021-05-13 22:34:30
Body pop
24 (100%)
1,266CR
So back to this again guys ,
Here’s some pics ,looks like that board is missing ?
There’s a connector that’s not connected in bottom pic
Is there anywhere else I can get one ,apart from that link ?
They don’t seem to send to U.K.?
Another issue with this now is ,I can select game and coin it .but it won’t start
Anyway some pics for anyone interested
how to be a strong man mentallyBody pop2021-06-14 15:51:12
Purity
The Oracle
2,999CR
The first and second image look like the inverter board.
Same as what can be seen here:
http://www.ukvac.com/forum/playchoice-video-inverter-mtc-9000_topic375246.html
Body pop
24 (100%)
1,266CR
Thanks I was hoping that’s what they were
Are they repairable
I wonder could I swap the top one with the bottom one and get the right colours on the game screen ?
Body pop
24 (100%)
1,266CR
Purity said:
Can you verify if the PCB is ok outside of the cab?
It probably is but I would definately veryify that before I started messing about with the cab
I wouldn’t have anyway of verifying it I don’t think
Unless I send it to another pc10 owner here ?
Anything else is well and truly out of my league
There is that issue with starting a game ,I’ve tried tracing wires and they all seem good
Unless that could be connected to the fault in any way
Nes4life
1,134CR
I don't understand your second picture... Looks like the inverter is plugged into itself!! I think you are bypassing it.
Pull out both green connectors. The one that was going into the monitor should plug it into the inverter, then plug the cable coming out of the inverter into the monitor.
As for that dangling molex at the bottom of the cab, where does it go to? Trace the wires back. Shouldn't be too hard to follow. My guess is a system fan, coin counter or light.
PS I own a PC-10 and am happy to test PCBs and games. I think the above will sort it though. If you want to convert any of your games to better games (Golf or Tennis to Balloon Fight, Mario Bros or Duck Hunt etc) then send me a message!Nes4life2021-06-15 06:37:46
gunblade
9,149CR
its just as Phillip says, you have plugged in the game rgb direct to the chassis when it should go to the inverter board and then the inverter board should plug into the chassis
Body pop
24 (100%)
1,266CR
Ah I see what you mean guys !
Good spot . It came to me like that .
That’s weird I wonder how long it was like that !
I’ll give that a try later
And nes4life i shoot you a pm regarding the games cheers :)
Body pop
24 (100%)
1,266CR
My other problem with this cab is
When he cab is turned on and still ‘cold ‘
It plays ok ,then it looses left and right controls and game select and start
Other stuff seems fine ,would these ive mentioned be in a block connector together ,would it be a board fault
Or voltage
I’m not sure where I could measure voltage from on board?
It one of those old hantarex power supply’s
Nes4life
1,134CR
Looking at the schematics, there are about 7 ICs that the data from these controls travel on. As it happens only after a little bit of time, you could feel each of these with your finger and probably find one was crazy hot. Alternatively I'd use freeze spray on each of these one by one until the controls came back.
8C, 8B, 8A, 8E, 8F, 1K, 2K
