NLoader - NetBoot loader for Smartphone (sort of) - testers wanted
I wanted to be able to Load my NetDimm with my iPhone and after playing around with a few loaders, they either didn't work or were not easy to control from the iphone, so I decided to make my own.
What is it?
NLoader is just a GUI that is formatted to display correctly on the iphone (in particular the iphone4) to make it easy to change games on your NAOMI while standing next to the machine with an iphone. It is a windows program that resides on the PC that holds the ROMs and is viewed by a VNC connection from the phone to the PC.
What does it look like?
Here is a screenshot of my phone
EDIT NEW PIC AFTER CHANGES:
What is needed?
The program and ini file along with a VNC client on the PC and phone. I have been using teamviewer as the VNC client on both as it is free and works well. It also uses Ace's transfergame.exe.
Loader abc works for this, why bother?
As already stated, i couldn't get any loaders to work well with the iphone so I decided to create this. If you already have one that works well - great, letr me know what it is and I might start using that instead!
Is it configurable?
The IP address, rom paths/names, executable path/name and button labels are all configureable via the ini file. The number of buttons EDIT NOW:(95) (20) is currently not. EDIT: Now pictures and labels are also configurable!
Does this work on abc OS?
This is a windows only program and has currently only been tested on Windows XP.
Does this work on abc smartphone?
This has currently only been tested on an iPhone 4
Are you going to develop this?
Maybe, maybe not. If you have any good ideas let me know and I will see although my time is very limited. I made this for myself and just decided to share in case it is useful for anyone else, so if I like/want your idea I will probably implement it.
How do I install?
You need a VNC client on your PC and your smartphone. If you use teamviewer, i suggest putting the PC client in LAN mode and logging in with your PC IP address so that you don't get the annoying teamviewer 'thank you for playing fair' message that shows on the free download in WAN mode. The programme is a standalone executable so you just need to edit the ini file with the IP address of your NetDIMM and your ROM paths.
So, what do you want?
Before I freely release to everyone, I am after a few testers to see if it works on other windows platforms and other smartphones.
OK - I will test, but I am not technically minded?
No problem, all that you need to do is use the program and tell me if it works for you.
So how do I get hold of this?
Just send me a PM with you emaill addy, details of your OS and smartphone and I will send it.
Where do I get xyz ROM?
Please do not ask me, this is desgned for people that have ROMs for legally owned games and I will not respond.
simonden2013-10-25 21:16:52
What is it?
What is needed?
Is it configurable?
How do I install?
