No inputs responding // Primal Rage Cab
callebalik
1CR
Hi,
In the process of “restoring” an old Primal Rage cab that was made into a Mame cab somewhere along the road. Bought it as-is without knowing the actual condition. Have removed all parts used for the mame setup. computer, motherboard PSU, jpac and what I believe was some kind of audio amp. PCBs are booting just fine and is outputting image. screen is in great condition. Not sure if sound is working. Only apparent issue right now is that none of the inputs are working, no sticks or buttons. Where do I start troubleshooting? Wiring looks good from input panel to connector. Do I need to rewire anything after it’s been going through a jpac?
Sorry, I am pretty green on this… Have a JK cab since before but that has been mostly plug and play.
Happy for any help possible.
Cheers,
// C
callebalik
1CR
Thanks! With a multimeter? Honestly, I have even have a hard time figuring out which one is common ground :) Anyone that can point me in the right direction?
big10p
Coins detected in pocket!
6,093CR
The two connections with black insulation tape holding them together look like they might be ground connections, and look very suspect.
callebalik
1CR
Thanks!
Connections look fairly legit inside the isolation tape. Soldered and all.
So, trying to learn as I go here. Buttons and stick share the same ground, per player? If there would be faulty grounding between two buttons, would that break all the inputs?? Haven’t measured anything yet. Maybe I should check grounding upstream as well before that.
Thanks,
// C
big10p
6,093CR
Set your multimeter to continuity test. Put one probe on the GND connection on the switcher/PSU, then touch the other probe to each of the controls' ground connections, to see if the connections are good.
