Op wolf issues
Unit504
156CR
any advice on this, I have a working Op wolf board sound all everything.. only thing is the gun bullets or bombs do not register on screen.. I've done the normal things like screen brightness etc..
would this be a rom / chip issue..?
as I have another op wolf board with a sprites issue and the gun registers on this one.
what could cause the sprites issue and now the board just comes up BAD ROM
Board One: gun not registering
Board Two: Has sprites issue - but now BAD ROM (Does not boot)
Any help much appreciated..
Unit5042019-08-05 10:58:46
Body pop
24 (100%)
1,266CR
I don’t think the bullets not registering issue has ever been solved
Iron giant looked at my board for it at one stage ,he bought a light gun and stuff ,he even changed chips that may of been related .i think I got a replacement board and never tested his work
Anything else though ,he could always fix on my wolf at the time
Unit504
156CR
that bullet issue os quite a pain.. maybe some digging about might help..
now ive got a working sound board and pcb, only the pcb has sprite issues still on the characters..
would there be any part of the pcb i should be looking at chip wise to solve this problem?
kiels20
125CR
Get us some pictures of the pcb and the sprite problem on screen and I'll try my best to point you in the right direction. By no means will this be an easy one even desoldering chips off this pcb is horrible 5v and ground pins are a pain. I've got two pcbs off the shelf in the past month both different revisions and one has a bad colour custom package and also the bad rom message sometimes that's as far as I got with that one £60 pound for a replacement custom and the other pcb is stuck in reset and trust me I've checked every chip on the board by desoldering them all it took me about two weeks with only 2 trace repairs. I'm really wanting to get to know this board because there isn't much repair info out there and maybe I can help other people out in the future. Good luck with the repair buddy i share your pain and lots of other people do I'm sure with this game
Unit504
156CR
yeah defiantly not the most favourite board to repair.. the sprite errors are just jail bars on all the moving graphics ie: soldiers, vehicles etc.
thats what i have found there is a major lack of information on this.
Unit504
156CR
update with the help of Paul (paulcan69) and Kiel (kiels20), till 1am this morning, we have managed to correct the issues with jail bars on the moving foreground sprites..
now onto the gun registration, the gun is seeing shots on the screen but they are all over the place.. ive adjusted brightness on the HV and chassis itself, check ground to the gun - just going to check the volts to the gun..
Unit504
156CR
the gun is the original Gun (light gun) the whole machine is an original operation wolf cabinet and internals.
Gun was registering ok before the graphics issue, which now has been fixed, but the bullet/bomb registration is all over the screen. the registration is not accurate. (when it was before the graphics fault)
anyone any ideas on this.. :) or area to look at on the board. sound or main pcb>?
Asure said:
I assume the gun isnt a real lightgun but there are 5k pots for the x and y axis like a mouse..
Unit5042019-08-11 11:16:56
Asure
133CR
I keep confusing these, but this is indeed a normal optical gun. Post a picture of the unit, it may be missing the barrel part with the lens in it. Maybe lens could be damaged? Did you take the gun apart and clean it yet? Maybe the lens got inverted?
Everything I see online points to monitor and mirror cleaning and adjusting the monitor so that it's nice and balanced in regards to colours. You wrote you had adjusted brightness so there's that to correct back to normal level.Asure2019-08-11 13:00:49
Unit504
156CR
the cab and gun is complete, we have checked all the obvious things
Cleaned Monitor
Cleaned Mirror
Cleaned Front Glass
Checked and Cleaned Gun Len (and made sure it was the right way around)
Checked voltages to and from Gun and PCBs
Turned up the brightness on monitor
Monitor Colours/Brightness (also just been fixed) so all working perfect (thanks to Gunblade)
Tried a whole new gun - still gives the same issue (shots register on screen but are all erratic)
Corrected the Jail bar foreground Sprite issue (picture is perfect now)
Now tracing the gun sensor connections back to the sound board.
(there is something on the sound board not right)
paulcan69
946CR
I have 8 sets of op wolf board (Well a 9th that is working)
And 2x junk/spare main pcbs'
All with no sound and no shots registering on the screen
Something on these sound board/s dies
I'm sure the two are linked
Maybe a custom chip
I need to spend some time on these but 2 young kids makes that very hard
I wish someone would crack this common as muck fault
What Si is doing is good
We need to check where the signal goes from and to
paulcan692019-08-12 13:26:25
paulcan69
946CR
Just to confirm...
Si has checked sensor pcb has voltages
Cleaned mirror, glass and bezel
Checked all fuses,
Checked lens in gun is present and both ways around
Even tried a NOS gun on it, confirming it's not the gun sensor or gun
If you swap sound pcb to the one with no sound he has...it then doesn't reg shots at all
His other one has no accuracy
But IMO that's the start of whatever is dying, run the pcb for a few more hours/weeks and I bet he loses shots altogether
...And I bet sound at that point
THEY ALL DO IT - sh*tTY THINGS!!! LOL
kiels20
125CR
I've been helping si with this and I've just been looking at the schematics. The light sensor output goes to pin 5 on the sound board then through l13. C72. R7. Then straight through to the s connector pin 15 and then to the main pcb that then starts off going into a d type flip flop at ic 26.pin3. And goes out of that to a 74ls75 pin 13. Maybe have a look at that in the schematics.
The area in question is on the very bottom of the board bottom two rows more or less and on every sett I've got this isn't a very nice area prone to corrosion. Maybe check s connector. Ribbon cable and go from there. I am trying my best to work this board out and will be doing a big wright up on my findings soon. I would love for someone to attack the pc060ha on the sound board and figure it out I'm in line for 3 up to now.
Unit504
156CR
appreciate all the help here guys :) we will get this cracked sooner or later.
yeah traced back the light sensor the other day and that's correct what your saying.. will work on this more this week and weekend. just need to print out the schematics bigger and then ill be able to read them better..
5,415CR
I've never had Issue with the board with not registering shots myself, a few of you seem to have real bad luck with these boards and cabs that I've not experienced myself, I'm still on the replacement pcb I got when the original was faulty on getting the cab, sorted sound out and it's been fine again since
Did have issue not registering shots but mine was gun fault on sensor pcb, should of logged what it was, something daft like bad joint though as don't remember swapping components
Blimey, you collecting the boards Paul
I have 3 or 4 sets I think, my original faulty one, one in cab, another from complete cab I bought and probably 1 other from somewhere, gotta get a few while you can though
bonehead
I'll get pix tonight
50 (100%)
1,729CR
I would love an op wolf cab again but I had the same problem with shots not registering.
Once I got a fully working pcb I sold the cab.
That way it would break on me again??
paulcan69
946CR
I will fix em!!! GOD DAMIT I will!
I will try my hardest and try to get repo customs where I can...
There is defo something common that happens to these,
I have all sets out in the loft at the mo, ready to do (My test rig/workshop is up there)I have my op wolf adapter ready
I only have one working set left, Si (unit504) is a good mate - lives local to me, I want him to have access to spare boards as well
I just need time and with 2 young ones it's hard
The moment I concentrate on them, 3 seconds later 2 screaming kids and my Mrs doing her nut...always pulls me away from it
I need to be left alone and plod through it
We can do this between us...
Kiels20 has done a grand job so far, he pointed to an area of Si's other fault (jailbars in sprites) and we fixed that thanks to him
Once it's out there (The fix) we will all see more working op wolf boards will be about and for sale.
In fact I can then sell a few sets once that's done
Ace`
PlanB contributor #1
40 (100%)
4,040CR
I haven't worked on an Op Wolf pcb before but having worked on other Taito stuff I can guarantee the sound issues the majority of the time are going to be down to the PC060HA custom chip. Jotrin.com have some in stock but they wanted $55 each last I checked which was more than I was willing to spend.
Body pop
24 (100%)
1,266CR
I done the same ,board not registering ,got another board that fixed it and sold it .though I’ve just got another lol ,this is my third op wolf .
I really hope someone sorts this problem too,it’s one of the best games bar none
