Operation Bear - Op Wolf clone
paulcan69
946CR
Merry Crimbo as well dudes, hope Santa got you all arcade related stuff.
I got 3 arcade books:
Supercade 71-84
Arcade Fever
The Ultimate History of Video Games
Ta
andyman
1,059CR
Here you go
trm
2,877CR
Where did you find those Andy? I 'lost' the edge connector for mine, started beeping it out and lost the will to live :) Bit confused about the apparent P2 controls though?
If there is a full dox package that'd help loads!
paulcan69
946CR
Oooo Tim...whats the 24v?
I was going to make a loom up for bear to go in my op wolf cab.
Just don't know what 24v is for?
Off to read Andy's link now....
Thanks Andy
JESSYBR
163CR
hi everybody as you can see the bear only has a jamma connector.
i never connected 24 v on it only the normal connections
paul send youpm about schipping
paulcan69
946CR
Anyone else know of a link to the correct pinout?
Tim didn't you show me schems for it at some point?
But I think what you showed me had only basic hand drawn schems and no pinout/connection to and from info, is that right?
P-Man
International man of mystery
1,273CR
I would say you need to work the pinouts out for yourself, you are extremely unlikely to find schematics for it (hahah! the thought of it! schematics for an obscure re-engineered bootleg?)
You might get lucky and find a wiring diagram in a photocopied manual or somethgin, but i hardly ever see Op Bear bits turn up.
Andyman - shame on you. terrible link, terrible arcade knowledge. minus 10 collector points.
I can work the pinouts out for you if you send it down.
andyman
1,059CR
It was in a directory with the filename Op bear, I clicked it, it showed Op wolf 3, never seen Op wolf 3, put 2 and 2 together, got 5
paulcan69
946CR
I have 7 sets of op wolf, this thing keeps me up at night.
I want another option...so op bear and I will make an adapter...
Thanks Andy, I think I will take you up on that kind offer.
Once I get the pcbs from Jessybr I shall be in touch...
I think I will collect it from you (once you've had a chance to look at it) as I do want a number of pcb's
I'm very close to having my "must have" list of pcb's...these are what's left
(I know you have TMNT so I would have that....plus any others?) - Or you may know where to get them from? - Either way would like to do a deal on a few...plus saves me £10 per pcb postage doesn't it.
Here's my current wants...
Crazy Kong Part II, TMNT, Final Fight, Hunchback (CVS cartridge) Rainbow Islands, Robocop 2, Street Fighter 1, Sunset Riders, Shadow Warriors.
paulcan692012-12-28 12:40:02
P-Man
1,273CR
favouredson said:
I may be missing something here but are the pinouts not the same as the original???
You are missing something here.
http://www.crazykong.com/pins/Operationwolf.pin.txt
Operation Wolf uses a 22pin, and 18 pin edge connectors with a 12-pin pin-header connector. The photo of the bootleg pcb clearly shows a single edge connector... Its been a while since I've owned a pcb, but based on a vague recollection and the evidence here...
Unless you have some information to add that contrary to this evidence? ;)
