Operation Thunderbolt PCB help!
strykr
1,351CR
Well total joy has turned to being totally gutted.
The PCB was working fine but wasnt getting any sound. fired it up tonight to see if i could work out the sound problem and the pcb now has weird red and blue ghosting on the graphics, and they dont look right. like they have a red halo. and the blue is going into white too.
Im not very technical but this cost me a lot of money and would like to try and get it working, can anyone suggest anything to try?
bear in mind I dont have a scope or fluke or anything like that. im jsut an average joe.
All I can say is its not the monitor, and the voltages are good.
Here are some pics to demonstrate.
Please help!
strykr2014-05-20 21:28:26
strykr
1,351CR
The manual states it does a rom/ram test on startup and flags if there is a problem, then it goes into the cross hatch pattern. My pcb is just going straight into cross hatch which I gather means there isnt a problem.
Purity
The Oracle
2,999CR
Yeah if it says "Into Test Mode", then goes to the cross hatch and pattern I think that indicates ram/ roms are reporting ok. I think if you press the player 1 and then player 2 start button, it will move the screen on. Pressing Player 1 start again should confirm RAM/ROM OK
Purity2014-05-20 22:03:23
strykr
1,351CR
Yeah, pressing either 1 or two brings you into button test mode, or gun calibration and sight calibration, all working ok.
the no sound could well be the cab, but the graphics thing has to be the pcb,
strykr
1,351CR
Yes, it was. i paid through the nose and got it from a US seller, so its possible that it took a knock in shipping, but that doesnt explain why it worked fine (graphically) yesterday. i'd like to get it sorted out.
strykr
1,351CR
All sound was missing, but it was on the two faulty space gun pcbs I had as well, so that could easily be a problem with the cab, thats what I was going to look at tonight, but the graphics faults took the wind out of my sails tbh!
stevebm1
39 (100%)
1,269CR
glad you got an op thunderbolt for the cab mate,does the game play and the guns vibrate,even if you have no sound?,it looks like it may be a monitor issue,could you not knock up a jamma adapter to test the pcb in another cab?
940CR
Looking at it I thought it was Jamma, but according to Klov:
The boardset may appear to use a JAMMA pinout but the video lines have been remapped to different locations.
strykr
1,351CR
It does look like a monitor fault, but I've had a good twiddle with the pots and the rgb lines and cut off seem to be acting normally, i.e. even with red all the way down there is still that red shadowing around the sprites and the graphics look messed up.
I will make up an adapter tonight and throw another pcb in the gun cab, this should tell me if the monitor is at fault, and if the sound on the pcb is also broken, I did test the pots on the pcb and they were functioning.
Ben, it is a funky pinout, but shouldn't be a problem, one thing i haven't seen before is the 3 position rotary switch that controls the volume in the service panel, its connected to the jamma harness as rotary 1, 2, 3. What should that be controlling?!
strykr
1,351CR
Update, pcb still has no sound, i have a fried plhs18p8bn chip (dont
ask) and dont really know what that one does, but I have a layer of huge
graphics glitches, the text, graphics and taito logo and 80% of the
game demo in attract mode seem fine, the title, and the intro sequence
in the attract mode all have garbled graphics.
The problem i was having was indeed monitor related as I tried again today, and I have no red at all on the monitor.
Any tips or advice appreciated!
strykr
1,351CR
stevebm1 said:
did you make up a jamma adapter to test the pcb in a supergun/cab?,the sound problem,could just be the space gun loom?
I went the other way actually, and made up a jamma to space gun adapter and tried a normal jamma pcb and I got sound through the cab with that one.
stevebm1
39 (100%)
1,269CR
and did the jamma pcb display the same monitor image?
strykr
1,351CR
Yep exactly the same, thats when I discovered that somehow overnight, the contrast on the monitor had gone up to full, and the brightness control was broken. So with the contrast up I had all the colours working nicely but it was badly tearing the red and blue. With the contrast down the blurring went but I couldnt turn the brightness up. tried the screen pot on the lopt but it clearly isnt the problem.
I have no red now anyway so am looking at a broken pcb and broken monitor at the mo.
