Operation wolf electrical issues
BlocksRR
4CR
My machine has no sound and it skips the start button. So I've finally finish restoring my operation wolf cabinet so it can stand so I can work on the eletronical issues which are no sound which at one point It would just play though all the sound effects but now it's doing nothing again. And the start button when ever you add a coin it automatically starts the game even if the button is unplugged it doesn't matter to much but it would be nice to fix
Monstermug
1,807CR
stuck input resistor? as for sound you will want to check if its an analogue or digital fault. never worked on a op wolf before but general routine should apply.
BlocksRR
4CR
So I've disconnected the start wire from the motherboard and it still auto starts as for the sound I'm a newbie at arcade machines so I'm not sure exactly what you mean but I should mention I removed all the caps and tested them and they were fine and I do get static and every now and then a pop
5,415CR
If you have no sound at all, chances are it's the power missing to the audio amps, check the fuse holders etc from the Aux board that powers it, usually the issue
The wiring on the USA cabs are different to ones here but should have Aux same
BlocksRR
4CR
Well actually since I posted this I discovered if I hold the service button when you turn it on it sometimes just plays through all the sound effects so I know it's getting power
