Operation Wolf FIXED
Unit504
156CR
I am over the moon to say i have my operation wolf back up and fully working again,
with a massive thanks to paulcan69 and VectorGlow!!
As you know i had a faulty sound board on the game and then it developed a gun sensor issue
were it would not register the shots or anything on screen.
here is the original thread to my woes:
http://www.ukvac.com/forum/forum_posts.asp?TID=328858&PN=3&title=operation-wolf-sound-issues
http://www.ukvac.com/forum/forum_posts.asp?TID=329028
The board was sent to VectorGlow who worked on it and sent it back super fast!
Once i had the board back from VectorGlow,
paulcan69 came over and tested and check the power amp/volts etc...
Then we fired up the cab....
After that paulcan69 had a quick re solder of some parts of the gun sensor pcb,
and we replaced it back into the gun and ta dar all working!!!
So again big up to paulcan69 and VectorGlow, for get my machine working again great work guys
truly appreciated all your effort!!
paulcan69
946CR
Irongiant/Vectorglow will know exactly, but although I changed/swapped over maybe 6-8 chips, it looks like Phil (Vectorglow) changed 2 more, one right next to the Z80 (Can't remember if it was a 74 series chip?)
Plus 1 chip which I had changed from Si's other dead board, so that almost leads me to believe that the fault was kinda the same on the other dead board as well.
And Si has a 3rd board with no sound, I would love to hear what Phil did as it seems that this happens to all of them??
Or they have a dead sound board, no sound at all.
Also sorry Tim I chicken'd out on this but I was feeling bad for Si, I knew he was missing it and I know I'm a bad pupil, I'm going back a step as that was tooo hard for me that one, instead I'm swotting up of Galaxian based stuff and trying to understand the flow of logic on an arcade board so I will actually know what to probe and actually fault find soon!
I've been watching Randy's videos, + some great ones on Galaxian repairs, I now want a Galaxian board to play with (original I think please.... ? Anyone got one for sale, just so the schems are 100% the same as my board)
+ Watching videos of Fluke usage, I want a Fluke too, but also need to read up more as I understand now that a Fluke doesn't just magically fix it and that you need to understand what to expect at each chip/section on the board.
(I'm learning, I will never stop trying on this...I will get good!)
Anyways, Phil....?
Take it away Sir....:-
You fixed it by.....
paulcan692011-06-17 23:04:19
paulcan69
946CR
Irongiant/Vectorglow is the bollox, +100 for his service,
Si your more than welcome, we need to do some Essex meets real soon!
paulcan692011-06-17 23:06:08
Wim75
3CR
Hi, after a long time not using my operation Wolf, I switched it on and the shots were not registering on the screen. Everything else seemed normal, screen white flashing just no bullets to kill bad guys. I found that more people had this so let me tell how I fixed it. You have to measure the voltages on the 4 pin connector on the small pcb inside the gun. You should have -12v and +12v on some pins, see manual. I was missing the -12V. This pcb seems to get power from the soundboard. In my cab there is a small pcb with 2 fuses of .5A an 3A that feeds the soundboard. I checked both fuses but thet were ok. The problem was oxidation that made bad contact between the fuse holders and the fuses. A good clean of fuses and holders fixed it. Simple fix but you have to find it.
