I've been fighting with a PC I bought recently off here trying to get it to display on a Nanao 2930 monitor, I'm nearly at the point where I'm gonna give up. But, I'm almost there so will give it another chance before I finally give up and move onto another solution. With the PC being a USFF I can't just throw in a GPU and run Groovymame so hence using the CPU's onboard graphics.
Windows 10 = Can't get it to display once the drivers are installed.
Windows 7 = Can't get it to display once the drivers are installed.
Windows XP = I can get it to play games but it needs to manual configuration to get mame to load.
So after spending hours fighting with the PC this is how I eventually managed to get a picture on the MS2930 with Windows XP:
1/ In bios choose ata mode instead of AHCI, if AHCI is chosen then it bluescreens when installing XP.
2/ Install XP
3/ Install SP3
4/ Install netframework 4.0
5/ Install drivers, when you reboot after installing the VGA driver it's set to an incorrect resolution which doesn't display correctly. So reboot PC.
6/ When booting keep pressing F8 and a boot menu will appear in 640x480 which allows you to then choose to boot with 'enable VGA mode' option.
7/ Once loaded in VGA mode, if you then reboot the PC it reverts back to an incorrect resolution. To make 640x480 stick run a CMD prompt and type msconfig. Select boot tab and tick base settings option. This will allow the PC to boot in VGA mode, but the colour will always be set to 8-bit colour and mame won't load.
8/ Change colour to 32 bit in display properties.
9/ Mame now works but when the PC is rebooted it reverts to 8-bit colour and games wont load until you change it back to 32bit colour. I've tried using Powerstrip but it doesn't seem to stick.
Has anyone successfully got one of these PC's (or similar) to work seemlessly with a 31khz CRT monitor? I imagine something using a HD2000 onboard graphics would have similar issues to what I'm experiencing.
Cheers.
Vamino2018-08-17 23:34:45
2/ Install XP
3/ Install SP3
Cheers.
