OR2 problem
Atlantis_Ire
9CR
Hello i Just purchased an Outrun 2 Twin and had it diliverd today.
I set it up with all its connectors and put it into place to boot it up.
I switched it on and no sound or picture, so i did the usual checks opened seats checked all connections inside cab all look fine apart from both stacks have a green light on and a flashing red light.
Things i did to check.
Swapped Stacks and GD Roms, no change
Hooked up a LCD, still no pic
checked power to stacks, +5+12 fine
pressed both button on stacks ,does nothing
pressed service switch, green start buttons flash
pressed test button, nothing
The seller a nice guy showed machine working and i am sure it was but somewhere in between id say something either fell off or i did not connect right (99% sure i did) but there is that 1% of me been silly.
Hoping its gonna be a easy fix but knowing it is the question.
Any help appreciated in advance.
obcd
3,830CR
You should have 3V3 going to the stack as well. Is your system the chihiro version or lindbergh version? Since you talk about gdrom I assume it's the chihiro one.
Even without working game, you should see a gray screen with the chihiro logo. Normally, only the green led on the filter board should be solid on. (Besides the 3 power supply led's on the side that also should be on)
Basically, both left and right unit work independantly of each other. So, it's a bit strange you get no picture on both sides.
The way you describe it, it's almost as if the avip cables are missing. It's the thick short cable that makes a loop between the bottom of the chihiro box and the shiny plate just above it that also has the vga connector and the jvs connector.
So, green steady on and red flashing would be green / orange on an xbox which is consistent with no video cable connected.
2,272CR
This sounds like the game is running. Wouldn't do anything on the start buttons if it wasn't.
Very odd to have both sides blank and zero sound, you should hear the boot up noise and then a sound when it takes a credit, unless all the volume controls are set to minimum. Check VGA cables are ok. Do you see a flicker on the screen when you pull the power? Do the steering wheels move themselves at all once you've turned it on?
muddymusic2019-08-10 14:11:24
Atlantis_Ire
9CR
Ok I'll seem to have run into issue two now.
After a while could be 5 mins or a hour game freezes on the master side and player 2 looks for network or controller
Any Ideas
Sbdesign
SEGA collector
1,721CR
Player 2 is fine, that is what happens if it looses connection from master side.
The only issue is your master side on cab 1.
A idea to help stress test would be to put both in master (1 player mode) so if P1 freezes P2 can carry on. It may freeze after 6 min? but hopefully your not that unfortunate, but by leaving that on (p2) you can at least give that one a run out while diagnosing P1 further.
Someone else will need to help with the freezing, I would assume power or heat - are fans running?
Sbdesign2019-08-10 21:11:39
Atlantis_Ire
9CR
Well further into this .
I put p1 stack into p2 and set both to single player games to rule out network and to test both stacks.
Player 1 works fine but player 2 freezes in random spots and times. So I'd assume a sick stack.
Suppose it's off to Andy geezer or someone like that.
obcd
3,830CR
Chihiro's are very sensitive to gpu overheating. If the gpu fan or case fan aren't running properly, this can be your issue. (Mostly due to gpu fan)
The upper box of the chihiro (the dimm / network board) can be separated from the lower case by removing the screw on all 4 sides. (some are screwed in the filter board pcb) After removing the screws you can vertically lift the upper box. There is only one connector and no cables between the upper box and lower box.
If you power the unit without the upper box, you won't get a picture but you should be able to see if the fans are spinning properly and not clogged with dust.
In the mean while, you can check the xbox mobo clock capacitor (leaks very often) If it has leaked, it's better to remove that capacitor. It has no use in a chihiro. Other capacitors that like to fail after a while are those surrounding the cpu. (The cpu is under the heatsink that isn't having a fan.) Sometimes those capacitors are bulged on top and sometimes you see some brown stuff coming out. If that's the case, they are ready for replacement as well.
You basically can switch the upper case between the working and non working unit to see if that's causing your issues. You can even exchange the upper board in the lower case (the base board) to see if that might be faulty. (It's just a lot of screws before you can unplug the filter board.) In 90 % of the cases, the problem is located on the main board that is similar to an xbox board.
