Oscilloscope recommendations
Nes4life
1,134CR
Can people recommend an affordable digital oscilloscope as my vintage analogue oscilloscope gave up a few days ago (it was a 1979 Gould Advance 250B and it just suddenly started putting all readings 'off-screen' - I'll try to replace a few caps to fix it but otherwise I'll sell it as broken).
It just needs to have X-Y mode, not cost the earth, and be readily available to actually buy.
Of course if you're selling your spare then let me know too!
Thank,
Phill
yorkshire_spam
765CR
I recently picked up a cheap second hand (eBay special) Hantek 6022 (USB) - It's not as good as my old analogue scope, but takes up a hell of a lot less space (combine that with using a USB logic analyser and my desk is almost tidy!)
It says it has X-Y mode but haven't tried it yet.
Purity
The Oracle
17 (100%)
2,999CR
I bought a Siglent SDS1102CNL which is classed as a budgt scope. It says it has X-Y Mode
X-Y Mode
X-Pole Input/Y-Pole InputChannel 1 (CH1) / Channel 2 (CH2)
Sample FrequencyXY mode has a breakthrough that trad oscilloscopes restrict sampling rate at 1MSa/s. Support 25Ksa/s?250Msa/s adjusted.
Purity2018-12-01 10:30:33
TheDaddy
14 (93%)
7,230CR
I also have the Hantek 6022 - Does everything I have needed up to now. Very easy to use and very small. I would have preferred a dedicated one on my bench that does not need a laptop/desktop but you cant beat the price really. I suppose it depends on your budget, The more pennies you have the fancier they become but at the end of the day they pretty much all do the same (Providing its just PCB's For monitors ect they are not too good, Or so I am told but I don't do monitors ! ). There are some Hantek digital ones with screens ect (Link Below) I would have liked one of these. maybe in the future with any luck.
https://www.ebay.co.uk/itm/Hantek-DSO4072C-Digital-Oscilloscope-2CH-70MHz-Bandwidth-1GSa-s/132384197242?_trkparms=aid%3D555017%26algo%3DPL.CASSINI%26ao%3D1%26asc%3D20160706105120%26meid%3Dde52dba31111488aaa9e2dd82a086871%26pid%3D100508%26rk%3D1%26rkt%3D1%26%26itm%3D132384197242&_trksid=p2045573.c100508.m3226
Hope this helps,
Dave.
