[uk-vac] OT: PC cooling question - Innovative solution needed!
Hi Guys,
In my never-ending quest to silence my PC, I decided to give water-cooling a
go. I've bought a Waterchill cooling system, but of course buying and
fitting one of those would be far too easy (and noisy).
So, I want to take out the fan-cooled radiator it's supplied with and
replace it with a rad I bought off eBay for a Kawasaki GPX600. I figure this
size of radiator will let me run fanless. It will also fit on the side of
the PC case just fine. (Actually, I bought a GPZ rad as well, for
contingency...)
The problem I have is tube connections. The tube that comes with the
Waterchill kit is 10mm OD/7mm ID, and the connection on the GPX radiator is
a 20mm hose connector, and it obviously doesn't fit. See below:
http://www.centipede.plus.com/GPX/0.jpg
http://www.centipede.plus.com/GPX/1.jpg
http://www.centipede.plus.com/GPX/2.jpg
http://www.centipede.plus.com/GPX/3.jpg
First guess, I could use some 20mm ID motorcycle radiator tubing and
something to convert that tubing down to 7mm.
Anyone know how I can do this?
Alternatively, anyone have an ingenious solution that I would never think
of?
Anyone have any spare 20mm motorcycle hose?
Anyone tried this mouldable alloy paste stuff that turns hard?
What about flexible silicon sealant?
All thoughts appreciated!
Phil
Hi Guys,
contingency...)
of?
Phil
