[uk-vac] Re: OT: Virus help
Hmmmm, at least you didn't have a hard disk crash recently...<sigh>
Still, ran for over 4 years nearly every day, so can't complain.
Viruses, Virii! I've cleaned more PCs than you can shake a stick at.
Adware still easily is the worser of the two nowerdays!
One customer had over 835 counts of adware/spyware.
Another customer had a ridculous 1000+ viruses(rare to see).
Some system files sadly are damaged/deleted, e.g. task manager.
With Viruses, sadly most Anti-virus programs protect(hence the name) and
have difficulty wiping out the beggars once you're infected.
Some are killed off and some say "cannot be deleted" or "file in use" etc.
Best way to kill them is take the hard disk out of the PC and mount it
on another(as a slave of course), then run a full scan.
Check the process list in the Task Manager for "odd" file names, etc.
You the search on the PC and locate them, and if found it will become
obviously quickly if they are spyware/viruses. Most like to hang out
in windows/system32 even a "dir /od" from a command prompt will show
them at the end of the listing.
Also use Google to look for file name you think are suspect, this
works more for spyware as viruses use many names(some random) for file
names, more clever viruses just turn off the update on Anti-virus
programs to give the user the illusion of protection. Most contain
mini-mailers to spread themselves further.
If you're brave enough to use regedit go here:-
HKEY_LOCAL_MACHINE-> SOFTWARE-> Microsoft-> Windows-> CurrentVersion-> Run
Check the list again for suspect programs!!
99% of them go here so they're loaded as windows starts up.
Hope this helps,
Cheers,
DaveO (Virus & Adware killer 8th dan Black Belt)
<snipped of excessively huge file listing!>
