Outrun 2 SP + battery back up modification
lespotts
63CR
I recently purchased a lovely Outrun 2 SP from muddymusic which takes pride of place in my games room.
The Achilles heel of the Outrun 2 SP is the battery pack that saves high score and game adjustments
I checked the voltage and the news was not good, 0 volts. New battery packs are available from Sega but at the cost of £150+ which is not really an option. With a new Sega battery pack installed you have around 72 hours with the game switched off before it goes flat which would not work in my games room. So I found a diagram on a forum ‘arcade-museum.com’ which detailed a battery backup system for Sega Chihiro game board.
Following the diagram the parts were purchased from EBay and promptly assembled and tested.
The system can switch from mains supply to battery back-up seamlessly.
I managed to fit the wiring though an unused plug on the side of the Chihiro unit without having to modify the case
To prevent the Chihiro board trying to charge the new battery backup system I soldered a blocking diode into a fuse holder.
Checked the voltages from battery to voltage regulator
From mains supply
And output remained static at 7.1 volts
There is a feature on the regulator board that when you are happy with the voltages you can switch off the display to save power
A great bonus what I was not expecting was that the media board now holds the game download and no longer reloads the game every time its switched on
(this video takes time to download scroll down)
I tested the system for 4 days before fitting it to the game, I plan on putting the charging system on a timer to charge for 1 hour every two days
I would be interested in anyone’s thoughts good or bad as I am most certainly not an electrical engineer
Cheers Les
bbz149
26 (100%)
1,607CR
Cool
I was going to do the same to my setup but on a smaller scale! Glad to see you got that Diode in there as saves disabling the charging CCT on the Chihiro
G that battery would probably save the Game in Dimm for a few Years
2,204CR
I have always wanted a proper solution to this issue, my 30 year old track & field saves scores but outrun 2 can't manage it?! What an interesting way around it.
rcantor77
Candy Kid
223CR
That is cool and I have a few of those batteries lying around from my Alarm System... I think I will be trying this out very soon on mine.
Les, could you a complete parts list and links if you have them to the original post.. cheers.
lespotts
63CR
Hi Roger here's links to the items I bought of ebay
http://www.ebay.co.uk/itm/111254563499?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/191278074453?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/200918695585?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/400360943571?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/190881496479?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/300935741080?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Cheers Les
bbz149
26 (100%)
1,607CR
Yeah that's a real forker when you put it that way!
In the next few days I wont have to worry about slow loading times from cold boot, loosing High scores and will also gain Force feedback from in-car view
2,204CR
I think I can guess what you've bought then! I was very tempted for the new OR2 cab, but already spent far too much getting that so will have to stick with regular SP. In fact I'm gonna have to get another CF setup, feck going back to gd-rom
lespotts
63CR
vib_ribbon said:
does it take a separate 240v mains in?
All the games switch on from circuit breakers at the fuse panel so I can turn them off and on without moving them. I have plugged the 15 volt charger into a live circuit and plan to put it on a timer to charge for 1 hour every 2 days. It would have been possible to take the 240volts from inside the Outrun cabinet but that would not have worked for me as the games are sometimes switched off for weeks at a time.
Michaelm
0CR
I'm very interested in one of these too.
If you could also build me one anj and are willing to ship to the Netherlands ?
Not sure what that battery weighs though so it might be wiser for me to get that in the Netherlands to save on shipping ?
I have ordered the parts and should be able to build it myself :)
Michaelm2015-11-30 23:08:49
VIDEOTRONICSUK
99CR
ive built a couple up
but on chihiro dimm board battery connector im getting 9.8 volts
reduced voltage on regulator buttons
ive battery connector removed its reading 7volts on connector
but when connected to chihiro its reading 9.8v
any ideas?
