Outrun Custom Sound Chip Question
2huwman
375CR
As I understand it, the Outrun custom sound chips are impossible to replace. I have a couple of untested Super Hang On PCBs that look to have similar chips. Is it worth hanging on to these as possible donors if my Outrun sound chip fails, or is that not really feasible (assuming the Super Hang On Chips are working)? I've seen a couple of references to them being the same chip, but they look to have different number on them.
Some pics of one of the Super Hang On PCBs (the other PCB is in 2 parts, a bit like Enduro or Space Harrier).
https://photos.app.goo.gl/EKGBJSYnBbj5LX0i1
Thanks for any advice!
dj_yt
787CR
The upper Super Hang-On PCB is the same as the upper OutRun PCB, with different EPROMs and PALs. The PCM sound chip is the small surface mount chip next to the Z80.
The bottom boards are very different and not interchangeable. (i.e. you can't convert one game to another with a simple rom swap).
Transplanting the sound chip is a relatively risky operation in itself. So if it came down to it, you'd be better off repairing the off the shelf components on the Super Hang On PCB and getting the rest of it working.
Super Hang On PCBs are rarer than OutRun PCBs from what I've seen, so if possible I would avoid parting them out to fix OutRuns. OutRun PCBs are extremely easy to get hold of. Instead I'd try to trade the SHO PCB with someone when the time comes.
dj_yt2017-11-26 19:27:12
