OutRun Distorted Sound Fix
dj_yt
787CR
My OutRun suddenly developed distorted pcm sounds. This was most noticeable when completing the game. The congratulations voice sounded like it was being spoken by a robot. It did not affect all pcm sounds however.
The sound roms can be loaded into a sound editor as raw files. I was able to isolate the congratulations voice to IC 69.
I pulled the EPROM, and verified it with Romident. It failed.
Programmed a new one - problem fixed. Why can't they all be that easy?
5,332CR
Admirable!
Lesser/lazier mortals would've pulled all sound ROMs and checked the lot.
I should get a sound editor installed.John Bennett2018-03-26 22:31:31
nurtuo
326CR
Great work.
Very clever stuff.
I am still getting a slight clicking noise on my restored cab.
I swapped boards. Same.
Disconnected the marquee light. Same.
Swapped audio amp. Same.
Swapped noise suppressor. Same.
Lost a bit now!
dj_yt
787CR
Can you hear the sound even when the PCB sound is muted (i.e. in test mode screen)? From what I've seen most outrun cabs do this to some degree. I've not tracked down exactly what it is or whether it's fixable. It's very slight on my cab and not noticeable unless you stick your head right by the speaker, have no sound playing, and the volume cranked up.
I solved a similar issue on afterburner randomly when I swapped the PCB. So it could be something to do with the amplification circuit on the PCB itself. However, I usually can't reproduce it with the PCB on the bench.
Hurray Banana
2,766CR
Good work Chris. I'm sure my Power Drift has a dodgy sound when one of the laps are announced. May have to look at that at some point in the future (maybe far distant future
Hurray Banana2018-03-28 22:01:24
nurtuo
326CR
I just checked and it still there on the test screen.
I can hear it but it is just not such a clicky noise on the unrestored one.
I can hear it on the old speakers and the new shielded pair as well.
Its driving me mad.
