Outrun fan interferance
Gaming Heaven
106CR
I disconnected my Outrun monitor fan a few years back, as any owners will know it fits close to the back of the monitor and my one was interfering with the image causing a pulse.
In this hot weather I slightly worry leaving it on for extended periods and it is not practical to get to the back to open the back door ajar.
If I source a brushless fan will it eliminate the issue as there are no brushes to cause the on / off interference?
thanks in advance
limpy
132CR
grab a pc cooling fan and try running it off a power supply of its own.if ok find a 12v supply in the cab and try again
Gaming Heaven
106CR
ok thanks
could do this, are you saying the issue is not brushes?
I think the monitor and fan both takes 240v mains feed
what difference does that make though?
to clarify it needs to be a powerful [240?] fan as it is cooling the entire cab and the main ventilation point, just happens to be close to the monitor
limpy
132CR
could be the fan,could be your power supply in the cab or poor insulation on the fan cable.
12 volt dc or 240 v ac.
if its a 12cm fan it should still shift the same sort of amount of air.its not like the mains fan runs at 100,000 rpm.
some modern pc case fans are very good and very quite too.
and its better than no fan :)
PaulSwan
ZZZ
1,118CR
I've been using ADDA AA1282DB-AT 220V-240V 50Hz/60Hz low noise, low power ball fans in my Zac. cabs without issue so far if you're in the market for a 240V standard sized (120mm) fan.
Paul.
segaarcade
118CR
YEAH; ABSOLUTLY NEED TO COOL DOWN CABS, AT THIS HOT TIMES!!! THERE ARE A LOT GOOD FANS OUT AT PC SHOPS, IF you want go only with orig parts, use an other size matching sega cab used fan! thanks...
