Outrun Gears
Gaming Heaven
106CR
Hi everyone, opinions needed.....
When I got my outrun I was told it had a new gear, gear B I think, well if you look at the photo, sorry not a great photo, I have spotted cracks on both plastic gears near where the allen bolts run - could it be they have been over tightened? what else can cause this?
The game has had minimal use since I owned it
also maybe I am crazy but I thought as a solution I can fit super heavy duty auto grade jubilee type clips [you don't need to remove the gear for the type I will get] as the weak point seems to be on the non cog part of the gear
the cogs seems fine
I am about to clean off the wrong grease I applied and apply correct silicone grease
thanks in advance
cmonkey
1,659CR
Cracks in gears A and B are VERY common on OR cabs. You'd struggle to find an OR these days with non-cracked gears. The gears are comprised of a central brass core surrounded by the nylon outer shell/teeth. The grub screws go through the nylon and brass and secure the gears to their respective shafts. The fact that the grub screws have to go through the nylon outer shell obviously means that there needs to be holes in the outer shell for them to go through. These holes are the weak points of the outer shell and eventually the stress that the gears go through manifests itself in cracks near the holes. I wouldn't be surprised if you also didn't have further cracks between the teeth of gear B (the smaller of the 2 gears), you'll find this out when you clear the oil based grease from the gears.
You've probably also got cracks on gears C and D too.
You can still get hold of NOS gear B's from the States but they're not cheap (about £70).
Jubilee clips will prolong the life of the gears. Obviously you need to make sure they don't foul anything when the steering is moved from lock to lock. But if you've started to get cracks between the teeth of gear B then that gear is already living on borrowed time, I'm sorry to say.
dj_yt
787CR
One of the steering mechs I just dismantled for my OR restoration (see jammaplus) had the cog held on with tight tape around the centre and a cable tie.
The steering mech still worked fine but obviously it fell apart once removed!
I think a lot of operators just bodged fixes to this back in the day. I read of one steering mech repaired with an elastic band and the pot wiring inverted to compensate.
Is there any cracking or fractures on the main metal housing? That's what Ive just found on mine!
cmonkey
1,659CR
Not brass (don't think I've ever seen the gears made from solid brass) but there is a seller on eBay who sells gear B's made from solid steel. I got one of these steel gear B's a couple of years ago. My only issue with the mild steel gear B's is that they cause accelerated wear on the teeth of gear A due to steel teeth meshing with nylon teeth. If someone were to produce an all steel gear A then we'd be sorted for life!
dj_yt
787CR
Go for the 3D printed gears. They have been thoroughly tested and seem good. I've just bought a set for my restoration.
I would go for these over NOS gears also, as plastic warps and doesn't age well.
Solid brass gears are a great idea, but you'd want every gear replaced. Not just a single one, or it will cause wear on the other gears and then you're back to square one.
cmonkey
1,659CR
I can't speak for the quality of the 3D printed gears A and B but I got the 3D printed gears C and D from this same seller last year. The quality of them isn't great but due to the fact that they're the 2 non-load-bearing gears out of the 4 gears in the steering mechanism then they're more than adequate. I was then lucky enough to come across NOS gears C and D to satisfy my strange fetish for having all original parts. Sad, but that's me!
Reviews of the 3D printed gears A and B on KLOV are all good.
Gaming Heaven
106CR
where abouts on the housing do I need to check, do you mean the front housing?
Gaming Heaven
106CR
ok thanks for pic I will check but seemed OK.
I now checked toay.... gear C and D are cracked but game still operates ok, I will check if i can just order those ones the 3D type
A and B seem definately fine at the cogs no cracking that I can see so might just get away with the super duty jubilee clips!
GameOn
133CR
I bought a complete set of the 3D printed gears and springs (from the ebay link above, although I bought it direct) and although it took a while to dismantle as one of the gears just wouldnt come off, in the end I had to use a hammer and a piece of wood to whack it off.
I then had to remove years of grease and dirt and that took a while. I also added some new washers to the shaker, one issue I did have was the key for the B gear had split, I found some
NOS ones but it would have been about $40 after postage. I went to a hardware store, found a
square nail that was about the right size, as the cost of three nails worked out to about 6 euro cents, the guy thought i was taking the piss, even after I told him what I was going to use it for, he just told me to take it and f*ck off. After cutting and grinding
it fitted and worked.
Once it was put back together it worked a charm. As for life, they have been used on a machine in an exhibition that gets used at least 35 hours a week for over 10 months and the gears are still looking in great shape. The price is good, esp as any NOS A gears are nearly as expensive.
dj_yt
787CR
The 3D gear chappie recommends finger-tight for Gears C and D. I would recommend not going too tight for A and B.
The steering assembly is without a doubt the worst part of an OutRun cabinet to dismantle, mainly because it's absolutely filthy. I used Autoglym engine cleaner on mine. Plus, as some of you have found, you often end up having to get out the hammer to whack it apart!
Gaming Heaven
106CR
disassembley is exactly what I want to avoid!
the hose clips are far too bulky I checked today
so either I try standard jubillee clips but I don't think they will grip very well
also my gear C is badly cracked but still working ok but there is some dead zone on the pot where it is cracked
I also like the idea of weaker springs to protect the whole thing
dilemmas!
ataritoobin
199CR
When I rebuilt mine with the 3D printed gears, I initially tried the lighter springs and found I didn't like the lack of resisitance compared to the original springs, so I put the old ones back. YMMV of course!!
