Outrun Maintenance
sicoe
17CR
Good Morning All
First off i want to thank everyone for there help and support on this site.
Im Going through my Outrun Upright Can trying to get it in better shape, currently the Accelerator Pedal and Gear Lever are very stiff and squeeky and wondering what would be the best thing to use to try and resolve this.
Regards Simon
dj_yt
787CR
I'd recommend removing both from the machine and giving them a good clean, removing all grease and dust then replacing any obviously worn components. If this has never been done before, I imagine both will be in a bit of a state.
I've found dismantling the pedals and the stick and then cleaning each component individually gives the best result. You may also want to replace the springs in the gear-lever which have a tendency to weaken over time.
The gear stick assembly can be found here:
http://reassembler.blogspot.com/2018/08/outrun-steering-shifter-disassembly.html
Mr20to5
1,366CR
I remember taking the pedal assembly out of my first cab (Scud Race), I couldn't believe the amount of dirt, fluff, metal shearing, crap, cig butts, etc etc. The difference was very noticeable.
sicoe
17CR
This is excellent thank you, any special cleaning products used or spray to add to/clean these?
Thanks Simon
dj_yt
787CR
I'm sure everyone has their personal preferences - you can use an automotive degreaser if things are really bad!
But just a stiff brush and a bucket of hot soapy water should be fine once removed from the cab.
namfreak
92CR
Autoglym Engine and Machine cleaner - in my opinion there's no degreaser that can touch it (when agitated with a brush)
If things were squeaky that suggests they were dry and unlubricated
Once things are cleaned up a bit of grease works great on steering gears and pedal potentiometers (and the sliding plastic "bearing" that the shake motor operates)
Any smaller moving parts would respond well to a lighter lube that "creeps" such as WD40
sicoe
17CR
Good Morning All
i managed to order the new NOS Springs from Arcade fix it, when they arrive and i fit them is it recommended to put anything on them to make them run smoother or just fit and leave as they are?
Thanks Simon
namfreak
92CR
You won't need anything on the springs themselves. It's only where you've got two components moving against each other that a bit of lube helps
But as Nurtuo has suggested - the only way to do a proper job is to strip and rebuild everything
(Nice job by the way - I got my parts equally clean but those chrome pedals are a joy to behold!)
nurtuo
326CR
The NOS Springs should have an oil on the surface to stop rust from forming anyway.
It's well worth using those springs because you will get a good steering return.
I have just finished my Pole Position Steering Rebuild and it's great doing this stuff.nurtuo2019-09-16 09:12:35
sicoe
17CR
Hey Guys
looking to paint the wood underneath the steering panel, any ideas on what paint to use for this.
