Hey dudes, I've done a lot of the wiring in my Outrun Mini cab but have a number of connectors that I can't match up. It might be that I am missing parts e.g. Monitor
Anyway if you can help it would be appreciated
Here are the wires:
3 Pin Female Connector - Green, Red, Blue
2 Pin Female Connector - White, White/Red
2 Pin Female Connector Black, Yellow (Off Capacitor)
(I think all of the above are monitor related???)
4 Pin Female Connector (Brown Connector) - Brown, White, Orange, Yellow connects to A19, B15, A20, A24 - no idea
and some cause for concern.............
Purple wire coming from the top of the 4th fuse (2A) which is cut, and doesn't go anywhere
Blue wire coming from the 5 pin terminal plate. 3rd wire down is cut, and doesn't go anywhere
Both labelled either 100-120v AC. Not protected in anyway and still connected to the fuse block and terminal plate!!!
A wiring diagram would really help. I found the Outrun Mini manual that I found to be fairly useless tbh
Any help would be appreciated!
EDIT: Figured some out:
3 Pin Female Connector - Grey, Red, Blue (Off service panel - volume) connects to
3 Pin Male Connector (off 12v Power Map) - Grey, Red, Blue
3 Pin Male Connector - White, Orange/Black, White/Brown (Off service panel - switches) connects to
3 Pin Female Connector (Brown Connector) - White, Orange/White, Purple/White
4 Pin Female Connector - Yellow, White, Yellow/Orange, Yellow/Green - connects to B17, B1, A1, and A2 - so coin switch related - I have nothing to connect this too
Purity2016-09-01 16:28:59
Here are the wires:
