OutRun pcb fails AGAIN :(
2,272CR
Finally put my cab all back together (yay!). Got 4 credits on it before it went like this:
I swapped out my spare good cpu board and it's exactly the same. This is my last good video pcb...I'm expecting this might be the end of this set. What do you reckon?
J69
281CR
I want to put the upgraded ROMs in mine but I'm scared to touch it!
Is it always the same board that breaks? May have been left in poor conditions in its earlier life if it's prone to breaking regularly
caius
588CR
So fault is in VIDEO board (the one I repaired but the original fault was different), specifically in the sprites generation circuit, I only hope the custom '315-5211' has not failied (Ken 'irepairsega' told me he replaced four of thus custom in one year..).
Can you launch a RAM test and possibily also try these diagnostic ROMs:
http://www.aaldert.com/outrun/memtest.html
caius2018-08-23 15:21:40
2,272CR
caius said:
So fault is in VIDEO board (the one I repaired but the original fault was different), specifically in the sprites generation circuit, I only hope the custom '315-5211' has not failied (Ken 'irepairsega' told me he replaced four custom in one year..).
Thank you. I'll give that a try.
dj_yt
787CR
I (attempted) to repair an OutRun PCB with a similar sprite problem earlier in the year.
I initially replaced one of the buffers involved with addressing the sprite ROMs which solved the first problem, and then a fault similar to the one shown developed. :(
I ended up suspecting one of the sprite customs, but never fully proved it as I haven't tried replacing the custom itself. Might be worth dropping retroclinic a line to see what he thinks.
dj_yt
787CR
Our memory tester only checks the sprite ram. Most parts of the sprite circuitry can't be tested in software.
The sprites are rendering in the right locations, but garbage data is being pulled from the ROMs.
This could be bad sprite ROMs (unlikely if all sprites are screwed, plus you just replaced some of them), bad glue logic or a bad custom. You'd need to get the PCB on the bench really to fix this one.
Outrun2
Colonel Outrun
1,184CR
Such a shame and so frustrating.. makes you want to avoid turning a cab on when you get failures.
Have you checked the 5v to the board? If it's too high it might be causing damage. OutRun is hungry but something like 5.5v or more will be too much!
2,272CR
It’s a c*nt. New monitor, marquee, sound amp, springs, gears & 5k pot and rebuilt steering completely, pcb repaired from 2 board sets...all for 15 mins play. Was really nice while it lasted.
caius
588CR
If you can, check the 74LS373 @IC3-IC6-IC8 as well as the 74LS45 @IC1-IC2-IC4-IC5.
I guess you already dumped the sprite ROMs and they are good.
caius2018-08-23 18:17:15
nurtuo
326CR
But what a 15 mins.
But fear not it will be back.
obcd
3,830CR
If the repair is very hard or 2 expensive, you could consider cannonball on pc. They even have an io board so that it can work with all the original cabling. The gaming experience will likely be identical to the original. it probably even runs on a last generation raspberry pi.
