Outrun pcb faulty
Shinydaz
814CR
I picked up an outrun cab, untested with no chassis, its all I could afford, or I'd of brought a worker. Thankfully I had a spare chassis and the monitor is good, now moving on to the board.
Unfortunately it doesn't work, its just constantly resetting. I've swapped out the 68000's, checked the roms, I've even tried the test roms, but to no avail. So Im guessing its either the work rams or the damn fajitus around the cpu. I've a good clock signal. Any likely candidates to check out before I build an adaptor for my test bench?
Thanks.Shinydaz2020-11-04 09:35:42
SUPERSPRINT
1,035CR
It’s not necessarily the voltage that’s the issue it’s the ability to provide the current, so your psu may drop voltage under load or simply cut out under load and reset. Worth a check before you delve too deep into the pcb. SUPERSPRINT2020-11-04 20:58:39
Shinydaz
814CR
No change sadly with the new power supply. The 3 flexible interconnectors Ben?
I'd like to at least get it on its knees just to check the custom sound chip is good.Shinydaz2020-11-05 08:31:05
Shinydaz
814CR
Well I can see the slave/2nd 68000 is running but the main 68000 is just not running, swapped it out for a new 68000 but no difference. I've disabled the watchdog to see if I can track down the problem.
Can anyone verify that pin 13 on ic86(ls112) is a floating pin? I'm guessing it not
I don't want to desolder stuff unless I'm 100% sure its faulty, I hear these boards put up a fight getting stuff off.
