Outrun sitdown not booting
sclark
22CR
Hi all,
New member here, but know a number of you from years ago, so hello to all and happy new year.
Having got my cabinets out of storage (in some cases 7 years) recently, I've been working through setting them up again.
Turning on the outrun sitdown has sadly produced the following image on screen, with no motor movement or sound. The board is revision B, top board LED is bright, lower board LED is dark. I have tried running without io, speakers, motor etc in case the helped, as well as switching top and lower board power plugs but no joy.
Any advice on potential remedy, repair, replacement etc very welcome.
Thanks in advance
Steve
smarty
Ready Player One
1,305CR
Hi Steve,
I'd you're going to need to verify the 5v line that powers both the CPU and Video board. Verify it's within spec and go from there.
There is now a Ram tester that you can burn onto four CPU eproms and it will give a good indication if any CPU ram has gone faulty. Cleary the board is outputting some thing.
http://www.aaldert.com/outrun/memtest.html
Is the image on monitor stable or rolling like a sync issue and does the image change?
Regards, Mart.
sclark
22CR
Hi Mart,
Thanks for that - I'll get out to the garage tomorrow and start investigations from the 5V then.
The image is stable and does seem to the be outputting the contents of memory, just not managing any sort of logic or initialising which suggests the CPU board is not functioning.
Steve
