Outrun2 - Drive Board Encoder error
corn
26 (100%)
231CR
Having finally got what was my club cart sitdown converted pretty much fully to Outrun 2, I sat down for a decent game.
After about 10 minutes its developed a fault "Drive Board Fault Detected - Encoder Alarm" - bloody typical - gutted. I'd just finished connecting up the rear seat speakers and it was sounding pretty amazing. I've checked in the Service menu and the forcefeedback tests initially worked. After trying to restart the game the same fault appeared and the tests no longer move the steering wheel.
I'm not 100% but it did seem like of late the forcefeedback wasn't as powerful as I thought it used to be. I also noticed that on power on, the wheel didnt fully turn left to right - was pretty sure that the power on test turned the wheel fully from left to right?
I had a look through the Outrun2 manual and it recommends checking the motor wiring. For what it was worth, I had a look, but there isn't really a great deal to check. Having connected the wheel back up, it now reports something along the lines of main board not being connected to another board :-(
Any ideas - is my servo drive board dead (I still see a flashing red light on it so its not totally blown)?
2,271CR
I've had this fault and it was due to a loose cable nothing more. Same goes for the other fault too - guessing it was 'main board not connected to drive board'.
Removing and reseating the cables from the drive board fixed it both times. The cable running up to the dash has a join in it so it's worth checking that one too.
corn
26 (100%)
231CR
Cheers. I'll check all my cabling tomorrow. Just seems odd it was working fine one minute, then died the next.
The only thing I'd changed was the addition of some spliced speaker cables to get the rear seat speakers working.
Out of interest, do you remember if the startup steering tests move your wheel fully from left to right? - mine just moves a little each way. I'm sure it used to move more that it does now.
Outrun2
Colonel Outrun
1,182CR
Arrgh I feel for you mate- finally getting that machine up and running properly only to get an error message would reallly give you a sinking feeling
Like Olly says, check cabling particularly into connectors- sometimes the small pins in these AMP connectors come loose and can cause errors like this. I once had a similar fault when the pink (or blue) wire came slightly loose from the small power dist board next to the drive board - it feeds A/C to the drive board I seem to recall, but I could be wrong as I'm just back from holiday and in chilled out mode!
The startup drive board test should turn the wheel right most of the way then release. The wheel should just slowly return to somewhere near centre in a 'casual' manner. It shouldn't go left at all..
garysmith20012014-05-18 23:18:56
corn
26 (100%)
231CR
Yeh, I'm gutted. Most of the kids in the neighbourhood have played it now - certainly a lot more than I have anyway! Finally I get some free time to have a decent game and it plays up.
I'll give the wiring a good going over tomorrow. Failing that, I'll be taking that drive board you have in the For Sale section off your hands Gary.
corn
26 (100%)
231CR
Well.... I cleaned all the feedback board cables with contact cleaner, re-seated them and the others connected to the motor and.... Bingo ... works again. Thanks for the help chaps, appreciated.
No idea where the loose cable/bad connection was but hey, who cares - its working again :)
2,271CR
Glad to hear it worked
I remember how I felt the first time it happened to me and I though I was gonna have to find another expensive board, but no just a loose cable. The other one that got me was 'media board failure' which turned out to be the security chip not pushed in enough!
Outrun2
Colonel Outrun
1,182CR
Excellent mate, glad the advice helped. Just goes to show sometimes it's the simple things and it's worth spending time checking wiring/contacts.
Hopefully you can enjoy playing the game now..
