OutRun2 error 25
vib_ribbon
488CR
Turned my Out Run 2 on for the first time in a few months and it's getting a "Error 25 Cannot access GR ROM drive." message.
This message comes after "Initialising media board please wait" during start up.
It's a Chihiro 3 system with a SATA drive.
The SATA drive appears to be getting power as the red lights on the connector board are on. I've tried disconnecting the drive, the power cable and the flexible data cable and reconnecting them but still the same error.
Any other thing I can try?
What is the likely cause?
Thanks in advance.
vib_ribbon
488CR
So this is how the problem was resolved in the end.
I spoke with Andy Geezer and we agreed I should send him the SSD with the adapter so he can check it out at his end.
He checked and found no problems at all.
In hindsight, I should have done the self check within the chihiro 3 before sending him the SSD, but I did it at this point with both of my media boards and sent him the details.
Andy thought it might be the firmware, I was doubtful since it has always ran fine on that particular version, but Andy's the pro so I listen to him. I suggested I should send him my systems and he can help me update the firmware at his end as I don't have a GDrom drive.
Instead, he said it would be less risky for him to loan me the GDrom drive & disc than for me to send 3 chihiro 3 systems through the post.
I received the bits and updated the firmware. Lo behold, the game works now. Well weird.
I'm just grateful it works again. I don't try to understand why.
Cheers Andy. Known him for years. Top bloke.
Outrun2
Colonel Outrun
1,182CR
Yea, Andy's a legend. Glad you got it sorted mate and it didn't involve an expensive fix!
Interesting updating the firmware after all this time with it working solved the issue. Did you update the firmware when you upgraded to SSD?
I got my SSD solution from Andy some years ago and he shipped the firmware upgrade disc to me at the same time.
vib_ribbon
488CR
When I bought the cab it was already running off SSD. When the original chihiro 3 died I bought a replacement from videotronics iirc and that was a direct replacement and the game worked on it without further changes and it has worked since. The original chihiro could not be fixed after I had it looked it, but the media board seemed ok.
A couple of years ago I bought a 3rd chihiro because it was offered to me very cheap, but that was on a really old firmware so I took the opportunity to update all 3 this time (minus the broken mobo).
Outrun2
Colonel Outrun
1,182CR
I wonder what the firmware was on the Chihiro before the upgrade when it worked, and if it somehow forgot and reset to factory after being off so long. Seems unlikely but you never know I guess.
I know the factory firmware version will not work with SSD/CF.
I'll have to fire mine up as they've been off for at least six months!
obcd
3,830CR
The type 3 dimm has a backup firmware. When the firmware appears corrupt, it will run the backup which is a much older version (and not compatible with ssd)
This could explain why updating the firmware fixes the issue.
