Ozma Wars Sound Modifications
9CR
I’ve been working on an Ozma Wars conversion. It’s the standard Taito 3-stack board set and once played Space Invaders; however it’s been fitted with replacement ROMS, it’s got Ozma Wars player cards and there are several modifications to the sound board.
The circuit surrounding the SN76477 was modified and it currently doesn’t work. Looking at the wiring I can’t figure out how it ever worked.
The modifications are:
1. The track to pin 9 (System Inhibit) has been cut so it is no longer under software control. Instead pin 9 has been wired to ground – so the new sound effect will be turned on continuously.
2. A resistor has been added to pin 4 (Noise Clock Resistor), a capacitor to pin 6 (Noise Filter Control Capacitor) and a capacitor to pin 8 (Attack/Delay Timing Cap). Fair enough – this will add some extra noise and variety to the old Space Invaders UFO sound effect. So far, so good.
3. Pin 22 (VCO Select) is tied to ground. This makes no sense at all. This will enable the external VCO control but there’s nothing connected to the external VCO control. So everything is deadly silent – until I remove this connection. This doesn’t make much sense.
4. The old System Inhibit signal was connected to a new resistor which had become disconnected. It looked like it could’ve been connected to pins 9-14 or pins 15-20 of the SN76477 but I can’t figure out how that would’ve helped.
Does anyone have a board with these Ozma War modifications? Or any documentation about the modifications (I’ve had a look around but can’t find anything). It would be nice to restore the game to its full (horrible sounding) glory but I’m probably missing something here.
(Picture enclosed)
All the best,
Simon
