Pac-Man Ball Pusher
Benny
1CR
Hi Guys,
Recently obtained a pac-man ball pusher, though after some short time i keep getting the same error. The error that is displaying on the screen is 1-14. This error code broken down is 'Jammed coins in coin hopper (L) causing the payout sensor to remain on'. On the test screen, its shows the sensor for the (L) to be left on. I've tried clearing out the coins from this hopper, and can't seem to find any jammed ones. I've also managed to click the test button, which shows all coins flowing fine. Can anyone help? could something else be blocking the sensor causing me to have this trouble.
When i start the machine up, it plays for about 5-10 seconds then this error with the sensor will always come on. I can provide more information if anyone knows anything which may be the cause, or i can provide pictures.
Thanks in advance to anyone who replies.
48CR
have you been into test mode and done the hopper feed tests to clear through any errors
here's a short vid of where to look
https://www.youtube.com/watch?v=WGqpxRlm0pU
let me know if you need any more help - I have one of these machines as well
Benny
1CR
Hi,
I tried doing what you said, and by using the menu i managed to dump the entire left hopper, so everything works find from what i can tell. The message displayed on the led screens says please check the coin reject cups, which have nothing in them
