Pac Man Boot issue - Garbled
Sbdesign
SEGA collector
16 (100%)
1,721CR
NOT MY SCREEN BUT SIMILAR
It scrolls all kind of things like the matrix, and starts filling up with a single sprite (different on different boots) then stays static after its full.
Any ideas what could be the issue? Anything I can try?
Please note the PCB has a HIGH SCORE SAVE KIT
ALSO was working fine until I tried it last night (had been off for a few months, in the house)
thanks for any support!
Sbdesign2021-09-29 10:01:38
TheDaddy
14 (93%)
7,230CR
Check the voltages are correct and also removed clean and re seat all of the roms. This is normally a ROM / RAM issue. The code is running but probably resetting after bad code.
Dave.
TheDaddy2021-09-29 10:13:53
bones
1,628CR
As said above, the IC sockets weren't great on these either. Is it a single PCB or the small double PCB set ? I'm always dubious about ribbon cables on those,I hate buzzing them out but feel the need to.
I'll be interested in what you find because I'm sure I've got a ms pacman boot doing something similar, I'll have to dig that out. Good luck
Phils Arcade
1,530CR
Yup totally agree. First check board voltages and power supply voltages, there can be a drop along the harness. Next move onto the ROMs and/or daughterboards. ensure all have good contacts and brush off any oxidisation on the chip pins. If still have issues, it may be time to pull out the schematics and check the address lines as these tell the processor where to get the data from ROM and RAM.
Was this a working board beforehand and just went faulty?
