Pac-man fault
my other pac-man on a galaxian board made by sublectro has a fault where the top of the ghosts heads are missing but only when it is on the top level of the maze.
This also effects pac-man when he is on the top level.
The game plays fine appart from this.
I have no idea where to start looking for this.
Please see attached photo
philmurr
48 (100%)
2,374CR
This looks like it may be a “feature” of using a Galaxian board to run Pac-Man.
Galaxian has a sprite clipping circuit to prevent sprites being displayed on the top 2 lines, so could be either that, or said circuit has developed a fault
cliff_poole
1,069CR
That's what I was thinking. Maybe check your other board, see if it has any extra mods, cut or patched tracks, that have been missed on this one.
Cant see any cut or broken tracks and no added or removed components.
Don't know if this means any think but the faulty board uses 74s201 sprite rams and no pull up resistors where as the good board uses n86s16 with pull up resistors.
Could the trouble be on the small plugin board that holds the sprit eproms ?
big10p
Coins detected in pocket!
6,087CR
If this issue isn't related to the clipping circuit mentioned, that would be a remarkable coincidence. Too much of a coincidence, IMO.
big10p
6,087CR
positive logic said:
I`m sorry Big10p i don't understand what you mean ?
I know nothing about board repair, but I think that it's too much of a coincidence that the sprites are clipped at the top of the screen only, just like the Galaxian clipping circuit mentioned. Maybe your other board has that circuit disabled somehow, and this one doesn't, or the disabling mod has failed. Just guessing, but I don't believe in coincidences this strong.
big10p2022-06-03 12:39:52
Ok i swapped the sprite ram over from the good board and fitted new resistors but nothing has changed , the fault is still there.
Could someone please tell me which ic or ic,s form the clipping circuit ?
I do have the galaxian manual and circuit diagram.
Could some kind person please give me a clue where the sprite clipping circuit is ?
I`ve done plenty of looking on the net but not found anything of help to me.
This is pac man on galaxian hardware and i do have the circuit diagrams.
Any help is much apricated.
Robin
