Pac1 or Pac2 board ?
Umpa2020
5CR
Anyone able to identify what this board is - Pac1 or Pac2 ?
Also it looks like the board harness as been altered. Any ideas what the other connector fits ?
Ump..
Pic 1
Pic 2
Umpa20202020-07-01 16:37:34
Umpa2020
5CR
Yes it is running Ms. Packman but it does not say pac-1 on it like in the photo. There is nothing behind that sticker where pac-1 is in the photo.
Have any idea what that other connector is for ?
ataridude74
265CR
It's an alternative edge connector so that it could be used in different cabs with alternative connectors, see the pinout on the link provided,=.
You can use either, but the smaller 18-pin connector misses some stuff out so don't use this one unless you have to.
Umpa2020
5CR
I am wondering if that second edge connector was the original, and someone added the larger connector for the Ms. Pacman board. Or do you think it was like this from the factory so that you could fit other boards ?
I suspect it was a 3rd party alteration done by a company called the LogicShop from Yarmouth (no longer trading).
I am trying to find if it is an alteration - what board came with it from the factory.
Umpa20202020-07-02 20:55:57
Umpa2020
5CR
Also I am wondering if my bootleg cab's loom is wired the same as original Ms. PacMan. Are these bootleg PCB's pin for pin the same as the board they ripped off ?
Umpa2020
5CR
What I am trying to ascertain is what board would have been in this cab originally. The board is mounted on a perspex carriage, as is the monitor board and it fits perfect so that might reflect the original PCB just flashed with Ms. Pacman, but then the connector for it seems to be added on and the original much smaller.
What I do know is the JPM modified pac man, and called it Muncher.
http://adb.arcadeitalia.net/dettaglio_mame.php?game_name=pacmanjpm&lang=en
I would like to know what was the original board. And perhaps get one.
