Pacland Chips
jonhughes
1,157CR
This may be a stupid question but I thought I should ask. Is there any way of finding replacement chips for CUS34A (position 7A) and CUS60 (position 2B) on a Pacland PCB? I know these are customs but not sure if these is a way of duplicating or finding an equivalent without the use of a donor board.
Forgive my ignorance, but if you don't ask you don't get
cmonkey
1,659CR
There's no known replacement for CUS34A (the address decoder).
JROK has developed a CUS60 replacement board which uses a bog standard Hitachi HD63701 MCU with an external eprom. He doesn't sell the blank pcbs himself but has made the gerbers available so that you can get your own pcb fabricated and then populate it yourself. It's not pretty, but it is a solution.
http://www.jrok.com/hardware/cus60/cus60_an_owners_guide.html
RGP
Meeter & Greeter
2,039CR
About time that CUS34A was cracked by CCS (you know i'm going to write you a craktro!) seeing as you're the resident Pac-Land expert around these parts.
jonhughes
1,157CR
Thanks for the information, looks like I need a donor board after all. The replacement board looks just like my Mortal Kombat Turbo daughter board.
cmonkey
1,659CR
You can get a CPLD replacement for CUS34 from Mike J @ fpgaarcade.com. Cost is roughly 28 euro excluding P+P. I'm currently in negotiation with him to buy a couple for my Pac-Land boards as the legs on these customs appear to be made from low quality metal which blackens and perishes over time leading to legs which disintegrate when you remove the chip from the socket. The CPLD replacement has only been tested on Pac-Land but *should* work fine on Dragon Buster/Sky Kid too, though probably not Galaga 3/Gaplus.
jonhughes
1,157CR
Thanks for the info, I managed to get hold of both chips from a Gaplus PCB, I think. The chips aren't the only thing preventing the board from booting up. I've retired board fixing for a while now while the weather is picking up. It's not one of my greater achievements but I try and it keeps me occupied for long long periods of time.
Hope you get your boards going once again.
cmonkey
1,659CR
I'm not quite sure how you've managed to acquire a CUS60 from a Gaplus board as that custom doesn't exist on on that board??? Gaplus uses a combination of CUS15 and CUS62 to generate all of its sounds.
What's more interesting (to me anyway) is that you've been able to transplant CUS34 from the Gaplus board to the Pac-Land board, but you aren't 100% sure that that custom is actually working in the Pac-Land board due to other faults on the board. I'm very interested to know whether a CUS34 from Gaplus can be used as a direct replacement for the CUS34A on Pac-Land. The schematics show that CUS34 on Gaplus has extra address decodes that CUS34A on Pac-Land doesn't have. It could be that CUS34 on Gaplus has the extra decodes built into its logic and CUS34A on Pac-Land is a chip revision that doesn't have those extra decodes in it (and hence CUS34 *should* work fine on Pac-Land but CUS34A won't work on Gaplus) or it could be that they are 100% compatible on a logic level.
I've offered to help Mike J out with testing his CUS34A replacement CPLD board on a Gaplus board and if it is found to be non-working (due to the extra decodes not yet being implemented in the VHDL) then I'm going to help him implement the changes and test again.
The problem is I don't have a Gaplus board..... So, does your Gaplus board still work? If so, would you care to lend it me for the purposes of keeping these old boards alive and testing a replacement CUS34? If not then would you care to sell it me so that I can test and then sell it on once testing is complete? I don't really want to have to buy a board but will do so in the name of keeping these boards going when the customs eventually perish.
cmonkey2014-04-10 23:28:35
jonhughes
1,157CR
Well, it's true I'm afraid. Here is a picture of the 2 chips together. The one on the left came from the original Pacland PCB. The socketed one came out of the Gaplus PCB. The Chip numbers are identical. You can see I made a repair to pin 22 on the socketed chip. The Gaplus PCB had some corrosion on it and some of the other legs on other socketed chips broke clean off at the wall of the casing - so I didn't power it up couldn't see there being a hope of it working.
You never know the previous owner could have just put that chip into the Gaplus PCB. It works just fine in the Pacland though.
I have 2 Pacland PCBs - one fully working. I have 2 Gaplus PCBs - one fully working also.
jonhughes2014-04-11 07:27:16
cmonkey
1,659CR
Could you do me a favour then, to save me a lot of work. Assuming the legs on the original CUS34A in your working Pac-Land board are strong enough to stand it, can you try it in your Gaplus working Gaplus board and let me know if it works OK. If it does then I can report back to Mike that his CPLD replacement will also work fine in a Gaplus board and this will prove that CUS34A is only a minor chip revision with no differences in logic to a CUS34. Thanks.
jonhughes
1,157CR
Hi there,
here is a picture of my working Gaplus PCB.
You can see the chip type clearly.
Apologies though I'm not too keen on taking this one out. It has two repairs on the solder legs. So that chip most definitely came out of the non-working Gaplus board also pictured (red marks the sockets with broken legs stuck in them).
It doesn't look to be in too bad physical shape. It also has 3 of those HD68A09EP chips I was after.
Hope this helps.
cmonkey
1,659CR
In your first post you said you were looking for a CUS60, which Gaplus doesn't have. I presume you meant a 6809 CPU, which Gaplus has 3 of.
I fully understand about you not wanting to remove CUS34 from your working Gaplus board, the legs on that particular custom seem to very sub-standard, that's why I've ended up ordering replacement CPLD modules for my Pac-Land boards.
I'll have to put up a wanted ad for a working Gaplus board to test the CPLD replacement,once it arrives.
jonhughes
1,157CR
That's right, I did. It must be that one - what's confusing me is that I have the chip at 8A out of the board on the desk (assuming it is that one that is broken). It's been a while since I last looked at it, apologies I'm always doing this.
Lurch666
21 (100%)
4,519CR
Thread resurrect.
I'm working on a pacland.
Got it booting with some sprit glitches but all of a sudden it's constantly booting with the error 0 0 1 (actually it's 1 0 0 upside-down) and then resetting which means a possible problem with the sub CPU.
I have replaced a few components and checked the associated eeproms that are connected to this custom and plan of trying a few more but I'm beginning to think the sub CPU itself is failing.
I have followed the link to Jroks site but cannot seem to find the link to the gerber files so was wondering if anyone has them or maybe someone has already ordered the PCBs from the gerber and since as far as I can remember you have to order more than one does anyone have a spare PCB lying around I could buy?
Thanks.
