Pacman AC input voltages
petercasino
212CR
I've just received a working Pacman pcb to replace a non-working one in an original Midway cabinet. Before I plug the working board in, I wanted to check that the AC input voltages aren't going to damage the board. When I measure them with the non-working board they are 8.4V (manual says 7V) and 13.7 (manual says 12V).
Are those voltages within tolerance? I measured the voltage across one of the RAMs on the board and it was 4.9V which seems ok? Just don't want to fry my working board!
Cheers!
Equites
Chief Sheesher®
35 (100%)
3,329CR
They are OK Mike, Pacman supplies unregulated power to the PCB.
Rectification is done on the PCB itself which is why you are correctly measuring 4.9VDC on the RAMs.Equites2015-09-20 10:24:24
