Pacmania Black Screen
aussiekanga
69CR
Hey all,
I was wondering if anyone here is cluey with namco system 1 pcbs?
Before i go on i rarely ask for help unless i am really stuck and ive repaired game boards for over 20 years so i got a fair idea of whats going on and how things work but when it comes to this pcb errr i am about to give up.
Ok so i got this Pacmania sold as faulty dead and all it seems to do is display blank, Originally main cpu was stuck dead doing nothing so after replacing that plus testing the other 2 i got it to start showing signs of life but sadly still a black screen but now we have watchdog active and life on address/data lines
I have tested the main work ram which was ok plus main boot roms also ok. Going around pcb with scope i can't locate any issues in the main cpu, ram and rom area which will cause it not run or even show video. The only thing i can think of but correct me if i am wrong the key chip, If thats faulty can this causes what i am seeing?
If anyone has a namco system 1 they can remove the key chip for me and tell me if it just does nothing that would be great
Flinnster
The Dino King
29 (100%)
2,566CR
On the base board there are a bunch of transistors - a pair each that control a colour channel output. While it's highly unlikely all 3 pairs would fail at the same time, they are in a spectacularly badly placed location for knocks and dings, so perhaps worth a check.
aussiekanga
69CR
Thanks for the replies ill go over it again and see if i can find anything
The only issue i got it that one or more of the smd customs maybe a issue and i have no real way of testing them other then using a scope. I can test some of the socket customs using other working namco board sets i own that use these
One thing that does come to mind is that if the key chip is faulty i wonder if it will cause this issue i am having?
Funhouse71
1,084CR
I'll dig my Splatter House out tomorrow and pull the custom and let you know what it does.
If it is that then it may be worth burning the custom free roms for it to get it back up and running again.
Flinnster
The Dino King
29 (100%)
2,566CR
Alongside patching my PacMania to do the highscore saving, I also patched out the need for the key chip. Worth using Aaron's RomPatcher perhaps?
aussiekanga
69CR
Ill give that a go and see if anything changes.
So going by what your saying the board will run without the key chip installed once you use the patched roms or does ir still need to be installed? I havent looked fully into that area on the schematics
Funhouse71
1,084CR
Hi,
So I just tried Splatter House with the custom 181 chip @ F10 and the board tries to boot but then briefly flashes up the words 'Game Over' on a black green then repeats not sure if this is a tongue in cheek message as normally this WOULD mean game over for your board
As your board is not displaying the a similar message it could be the custom chip is partially working and stopping the same boot sequence as described above so to ensure it displays a similar message as mine I would pull the chip completely if you haven't already done so.
Gadget Freaks arcade rom patcher will patch out the need for this custom protection chip @ location F10 so you can run the board without it.
If you have access to some 27301 roms then you could actually change the game to any of the Namco system 1 games should you wish
Funhouse712021-07-23 07:38:45
aussiekanga
69CR
Thanks for helping me with that Funhouse. I can rule that out for now
If you remove the sound 6809 does it sit on a black screen?
Sadly i tried the patched version of pacmania and still same issue so i guess its somthing else. Ive removed F10 so with or without it fitted same issue stuck in watchdog loop
Just thinking what else i could try or check but i am running out of ideas due to the customs now :(
I guess i could try another game just the boot roms but i think it wont help at this stage aussiekanga2021-07-23 08:03:12
aussiekanga
69CR
Yes ive tried that and no change.
Im just trying to think what else would cause this to just not boot if everything from program roms,rams buffers ect all check out ok and working correctly. The only thing that comes to mind is its trying to start the sound section and cant hence why i asked if the sound 6809 is removed does it show anything on screen
aussiekanga2021-07-23 09:20:55
Funhouse71
1,084CR
When the game boots you should here a audible pop sound as the sound section becomes live to output sound ready for the intro sound to start so if you are not hearing any sound at all you maybe on the right track
Funhouse712021-07-23 09:39:29
aussiekanga
69CR
If you could remove V3 which is the 6809 on its own near edge of PCB that would be great, I not noticed any pop noise from speaker so i think i could be on the right track as thats all i can think of thats causing it not to boot up and stuck in a watchdog loopaussiekanga2021-07-23 09:37:00
aussiekanga
69CR
Ahuh interesting ok
This will give me somthing to look at now
Yes done that plus check it a working game board that uses that cpu just to make sure it does work
Originally the main boot cpu that does the program roms was dead so replaced with a known good one got me to this stageaussiekanga2021-07-23 09:46:50
Funhouse71
1,084CR
I have a logic probe to hand on my test bench so I could put my board into test mode and you do the same then I can probe some of the chips for you and see if you have the same readings then at least there will be no activity on the board except the test screen which if you can get to that you maybe one step further in diagnosis.
