PAL-GAL
Macro
2,016CR
There is a lattice program that will convert a fuse map for a PAL (of various types) into the equivalent GAL fuse map
called something like PAL2GAL or PALTOGAL
may need an old version of windows to run in though - old DOS command!
if you cannot find it I can post it when I get home ... (tomorrow evening)
pampurio
1CR
In the meantime, I thank you for your answers.
I have a pcb tetris bootleg to which nanca a pal unfortunately my programmer only supports gal
porchy
994CR
Not sure how many different bootlegs of Tetris are out there but if the PAL dump on my site is what your wanting to try then I'll happily convert it for you to test?
caius
588CR
He is trying to say that his Tetris bootleg PCB lacks of a PAL.I think he posted this request also on other forums.Anyway, there are a lot of variants of Tetris bootleg so it's hard to help him.I have a couple of different one.So, please, post picture of your PCB.
pampurio
1CR
hello to all sorry for the delay in responding but I had work commitments. unfortunately I can not upload the photo but I found the board in the forum under pld, it is the same change only sa audio section that uses a schedule with 3 76489.
with paltogal software i tried to convert pal n'2 but i always have the message rom at 45f bad ce, i probed the 4 pin pal are floating. I probably did something wrong with the conversion
caius
588CR
This is your board, I found picture on ArcadeItalia forums:
Now we can see it's missing the PAL in the lower left corner.As you said, we have on JAMMArcade PAL dumps (thanks to the user 'Luisikiko') from a board with pretty identical layout sound section apart:
I have converted the dump of the missing PAL from PAL16L8 to GA16V8 fusemap, I attach it here.Burn the JED on a GAL16V8 and let us if it works.
https://www.ukvac.com/forum/data/uploads/1573/Tetris_bootleg_PAL2.zip
caius2018-07-01 19:38:39
pampurio
1CR
ciao gal programmato, ma non è cambiato nulla dello stesso errore. Ho controllato il pin 18 da cat28c16 ed è alto dopo che termina al pin 12 di un 7400 al pin 10 di un 7432 che sono ingressi e al pin 14 di un 74138. Qui viene il mio dubbio tutte le uscite sono alte mentre i pin 1 2 3 4 5 6 hanno attività, non dovrei essere attratto anche dalle uscite?
pampurio
1CR
hi gal planned but nothing same mistake has changed. I checked pin 18 from cat28c16 and it is high following it ends at pin 12 of a 7400 to pin 10 of a 7432 which are inputs and to pin 14 of a 74138. Here comes my doubt all outputs are high while pins 1 2 3 4 5 6 have activities, should I not be attracted to exits too?
