Pandoras box 3
forcefulfil
EDOT King
17 (100%)
1,675CR
Hi guys
My question is,does a pandoras box 3 support 6 buttons per player?
I have a 6 button jamma cab,originally wired for sft2.so this had the extra kick loom.
I can't find much info on this problem coz were on a newer version now etc.
I was hoping some of you guys had more experience in this kinda thing.
Any help greatly appreciated.
(Ducks down from all the arcade purists )
Thx
Philforcefulfil2019-11-25 15:51:42
neoretro
1,121CR
Sbdesign said:
I Believe this is it.....
dimension=406x10000:&
Above is correct and it’s the same for all of them.
You’ll need to either get a loom with a male adapter to plug into your kick harness and then take the 3 buttons down to the last 3 pins but 1 on each side of the Jamma loom.
Or you can just take them off the kick harness and put them on the loom.
The only thing that should be there that needs replacing on the loom is the ground wires connected at the last but 1 pins on the loom.
You’ll need to put those ground pins on the last pin on each side of the loom.
