Paperboy Repair Help
Purity
The Oracle
17 (100%)
2,999CR
Anyone good at repairing Paperboy or Champ Sprint PCB's?
I've now setup a test rig, which I think is correct. I can see the correct voltages at the PCB from the AR3 and the switcher. The +15v is spot on but the -15 volts is somewhere around 14. something...which I think should be ok
The CPU is watch dogging. I've tested all the socketed roms and ram and they seem ok. Not sure where to go next really.. I always get a bit stuck when the CPU is watch dogging. What would be the next steps to take?
It does seem possible to disable the watchdog on the board. When I do this I am getting some corrupted graphics on screen. I'm using a CGA/EGA to VGA board so I can see the output on screen
Purity2018-01-19 11:33:35
Purity
The Oracle
17 (100%)
2,999CR
It actually might be useful testing out some of my main components on a working boardset if anyone can help me out locally? Mainly my CPU and slapstic. Don't think there is anything else custom on there, but could be wrong
Purity2018-01-19 11:54:40
karlcdoe
887CR
I think last time I had a pcb that wouldn't boot I did find that powering it up in test mode it was actually reporting a self test fail message (just visible amongst all the corruption) which I could see breifly between watchdog resets which led me to the right part of the circuit. That was probably quite lucky though.
in fact I have just located my selection of not very helpful repair logs... http://www.ukvac.com/forum/topic333623.html
karlcdoe2018-01-19 12:38:57
Purity
The Oracle
17 (100%)
2,999CR
Thanks Karl.
I have got the self test wired up.
I think I powered it up with the self test grounded and it gave me a blank screen.
It was only when I disabled the watchdog that I saw some junk on screen.
I don't think I disabled the watchdog and had self test grounded, but I suspect that probably won't work?
I'll re-test again and take some images
Purity2018-01-19 12:57:18
Equites
Chief Sheesher®
35 (100%)
3,329CR
Interesting, always assumed these used either 6502 or 68k.
No Fluke Pod available for the T-11/DC310 either.
Maybe make an adaptor for the T-11 using an alternative Pod like the 8086 so that you can run basic stuff like RAM/ROM?
Macro did something similar using a Z80 pod to S2650 with an adaptor.
Purity
The Oracle
17 (100%)
2,999CR
Paul Swans arduino tester supports the T11 for Champ Sprint and I think I did start putting together some checks for Paperboy.....however the arduino just tells me what I already know - the CPU is watch dogging on pin 19, and I don't think I can run any other checks in this state
They use a 6502 for sound in conjunction with 2x Pokey chips
Purity2018-01-19 13:23:26
Equites
Chief Sheesher®
35 (100%)
3,329CR
Do the Pokeys only handle sound or Inputs too? System II stuff does not sound very Pokeyish.
For testing, I would remove the Pokeys unless you know they are good.
I’ve had non-booting Atari PCBs on the bench before that had bad Pokeys messing with the CPU addressing.
Purity
The Oracle
17 (100%)
2,999CR
Yes quite likely for inputs aswell. I would need to check the schematics
I have tested them with my Pokey test tool and they are both fine
