I have a paperboy that I'm trying to fix for a friend, there is no picture on the monitor but you can hear the game credit up and play
when I say you get no picture its just like there is no rgb lead plugged into the monitor
there are 2 power supplies which both meter out ok and the x2 red LED lights are lit on the board
there has been some power supply re-wiring which goes to the bottom right of the game board, looks to be done ok if a little crude
I've used my standard res test rig on the monitor and you get a split fuzzy picture and I've also used a med res pc board against the monitor and that works too so I know the monitor is ok
I had a look at the RGB lead going top the game board and I've drawn a picture below from memory (im not in the workshop today) can someone tell me that the RGB lead is correct, I downloaded the manual but its basically just a maintenance/parts manual
any help with the fault would be much appreciated
quickly drawn up rgb picture below
jengineer2014-02-25 09:08:38
