Part needed please
justermin
4CR
I am in desperate need of the following part so that I can test my "The Invaders" arcade machine... 18000 MFD 25VDC Capacitor.
Does anyone have a spare to sell me or know of a modern replacement as this particular one is obsolete. The original was made by Sprague and Mallory USA make one exactly the same but postage is rediculous on Ebay listings.
justermin
4CR
This is the one I need. It's screw fitment but I can solder one if needed.
PaulSwan
ZZZ
1,118CR
The none-screw standard pin-type ones are $4 a pop from DigiKey. So far I've not replaced any screw type one with another screw type - the compact modern ones have much better characteristics.
Paul.
justermin
4CR
martin8or said:
Thanks, I also checked RS components.. I was wondering if I could up on the voltage as like you say they don't do 25v in that spec. Unfortunately my knowledge of electronics is limited so I don't know how Capacitors work fully and the importance of getting the correct sepcification.
So using a 40v will not cause me a problem?
justermin2018-03-29 11:58:32
justermin
4CR
Paul.
Thanks Paul i'll see if they ship to UK at a reasonable cost.
martin8or
144CR
40v should be more reliable than a 25v in the long term.
Check Mouser as they usually add on the vat and any import duty. I don't know if digikey do this yet as I haven't bought from them for a few years. Usually you have to place a minimum order to buy from the US (to get free shipping) or they charge a lot for shipping, that's why I looked for UK sources, it will probably cost the same and take a little longer to get here. If you can think of anything to make the order up then have a look at Mouser's site, see if they have what you want in 25v which will be cheaper. The ones I suggested I think are screw terminals rather than soldered.
PS make sure you read the data sheet to make sure the part is good for a power supply. If it says general purpose then that will also be OK in most cases.
justermin
4CR
Thanks for your help guys, I've ordered the one from Farnells as it is a perfect match and in the UK, quite expensive but hopefully it does the job and I can finally test this machine.
