Muerto said:This is becomming more and more interesting!
Did a bit of googleing so other people can see what you are talking about:
Parasol Stars HuCard:
-EDIT-
Will you need a HuCard like the above, if yes, there's currently 2 available on ebay.... I could buy one of them, and send it to you....
trm said:Hacking the controller looks to be very simple as it uses the same setup as JAMMA from what I can tell - each 'switch' is fed 5V and then grounded when the switch closes. So it should just be a case of wiring an 8 pin DIN to a fingerboard matching up the respective U/D/L/R and then seeing how many fire/start/select buttons are needed.
Muerto said:The Parasol Stars HuCard is not rare, last week there was 2 for sale on ebay... - and cheap too..
