i suppose one issue might be, will the pc monitor turn on/off automatically when mains power is supplied/removed. if not, you will need to turn the pc monitor on manually every time you want to play
other issue is a pc monitor wont look authentic like a real arcade monitor
perhaps a solution to both issues above is, go down your local rubbish tip and get yourself an old school tv for free (my local rubbish tip has a skip full of tv's) .. however i cant advise on getting your 'arcade rgb signal' to work with the tv, you would need a tv which can handle rgb scart for starters anyway (most do i think) .. then perhaps u would need a special cable made up, or some kind of video signal converter box....
jek342012-07-07 16:19:43
