PCB marking - PC
PhilT
154CR
Got a Model 2 CPU board that has a dead short on the main power rail. Amazingly the game still boots but it pulls the voltage down to around 4.5 and the game frequently crashes.
On the board I found a component marked as PC69, which looks like its experienced some heat stress, I assume its a capacitor of some type as it looks like a power reserve for the IC below it.
Anyone know what type it is and/or what a suitable substitute is? I wanting to know what I am dealing with before cutting it and seeing if the short goes away.
thanks
PhilT
154CR
Didnt know about cap band colours! Such a high voltage rating on a 5v line, guessing its ceramic. Cant seem to find ones that look like it for sale anywhere. Obsolete parts I assume. Any reason this cant be replaced with a standard ceramic disk cap?
PhilT
154CR
so I lifted the component and the 'short' remained. For future documentation I measured it at 27nf both ways so its ceramic cap of some description.
I say 'short' because its not one! My fancy auto-ranging multi-meter decided it was a short and showed 0.00 on the display while beeping convincingly. Its only when I started poking around on the second, fully working, CPU board that I got the same result and realised. Switch to ohms and its not short, the readings being similar on both boards.
Lesson learnt.
RaveN
1,325CR
Depending on how you've got the MM leads connected, any rail with large electrolytic caps on them will temporarily show a short when they have no charge, and the MM current then starts to charge them and the resistance increases.
It often makes my MM buzz for the first split second.
I'd guess it's a ceramic, class 1 C0G/NP0, and a Chinese creation, as no one else made ceramics in that type of package afaik.
Macro
2,016CR
ceramic should be fine, they were basically used since they fitted into the component inserter machines easily at the time, once they could copy with the more usual ceramic disc, they switched to those instead.
PhilT
154CR
Thanks for the confirmations.
I got my SR working, I put the original PC69 back in, scrubbed all the connectors rather than giving them a quick wipe and its playing fine.
Re the 'short', I have a Fluke 115, its definitely the MM and not how I place the MM leads.
Theres a couple of test point on the cpu board marked as vcc and grd and the MM detects short, I tried vcc and grd on various 74's and power rail caps and it always displays 0.00 and beeps continuously. If I put the MM on ohms, which is a different MM setting, the power rail charges up and settles after a few seconds. The MM does not behave the same for any other boards in the stack. Odd but at least I know to double check shorts in future.
