PCB power consumption
invzim
24CR
I'm working on a project that will power games, but currently don't have any way of measuring current consumption of the boards I own. I need to do some calculations on via widths, copper weight etc - so looking for some hard measurements.
Anyone got a lab PSU that shows consumption and can share some details?
obcd
3,830CR
So you intend to calculate power consumption based upon via width and copper weight?
Simply get yourself a 0.1 and 0.05 ohm beefy resistor (10W or 25W) Put it in serie with a power line and measure the voltage over that resistor. It will give you the average current consumption on that voltage rail.
Otherwise, at least tell us what boards you need the current consumption 4 and why you need it.
Battlezone
410CR
It sounds like his plan is the other way around. Discover the power and then calculate width/weight
of the traces required for a low IR drop.
The peak power consumed on each supply is going to be very PCB specific. We had a recent discussion on the topic and Jon/Porchy even did some measurements on one board. I don't have the required kit, but you'll probably need to specify some boards to get a meaningful number.
http://www.ukvac.com/forum/portable-pacman-project_topic351972.html
Battlezone2016-07-14 08:55:06
invzim
24CR
Yes, I'm trying to make a gizmo so I can play non-jvs 15khz games in my only cab, Naomi Universal 31k only cab :) Actually I do that already, but the components involved are both expensive and hard to come by - so I want to make something better.
1.5A for pacman is good info, and I wish I had a bench supply like that. What I'm after is, based on measurement, is typical and some some worst cases. I don't really trust the old manuals, e.g bubble bobble specifies 5A on the 5V, which I find unlikely.
