Phoenix arcade
RedRooster
1CR
Hi everyone,
New guy on here and looking for some assistance in getting a Phoenix arcade machine back working after a 20 year lay up.
The machine powers up, but doesn't take credits even though the coin counter clicks up when I flick the coin lever, display is a bit wonky and the sound doesn't work either.
Any suggestions where to start?
6,093CR
Looks like the game PCB is faulty. You may be able to fix the wonky monitor by adjusting the horizontal sync a touch.
6,093CR
There's a few people around who can repair boards, but I don't know who to recommend in particular.
As this cab has been lying idle for a long time, you may want to check all the connectors are on good, and also check all voltages with a multimeter.
RedRooster
1CR
Had a look at it this afternoon, altering the horizontal sinc just makes its worse, the best picture I can get is with the RH side wonky.
Also had a look at the coin switch, all seems on there but the coin counter only counts up when this board is (the one on the right) disconnected, not sure what it does as apart from the coin switch wiring the rest of it had been previously isiolated in the loom?
RedRooster
1CR
Found some real dodgy arcade technician wiring, I think the only tool he had was a tea spoon.
Found out where he had by passed the coin slot, then the wiring had come apart.
So at the moment, game credits, music, all functions, but the machine keeps resetting the credit to zero mid game for some reason.
Also managed to get the screen straightened up, so nearly there.
RR
RedRooster
1CR
Thanks,
Got the slam switch taped up but will look at how secure that is tomorrow, could very well be the problem as where I am working on it the floor isn't that flat so the cab wobbles a bit.
RR
RedRooster
1CR
Can't see a tilt switch just door switches.
The problem seems to be heat related as first power up I can get to the space ship then it crashes, after it crashes sooner and sooner.
PSU is giving 5.00v & 11.84v.
Will try a bench psu on the 5v line tomorrow to see if that helps.RedRooster2019-06-26 19:57:36
philmurr
48 (100%)
2,378CR
First off reseat the CPU and all EPROMs
Then if that hasn’t fixed it try the test ROM as there looks to be some RAM corruption on the last photo
RedRooster
1CR
Top man Phil,
That did the trick the game is sorted, even managed to get past 3 mother ships with my rusty fingers
Thanks again to everyone for helping.
RR
GameOn
133CR
The sockets on most versions of Phoenix are horrible, I would heavily recommend getting them replaced with machined or at least double wipe sockets.
