Phoenix boot. Bipolar proms programming (REPAIRED)
kiels20
125CR
Hi guys im just starting to repair a bootleg phoenix pcb. I got rid of mine a while ago and regretted it so I came across one that is poorly and missing a few parts. Two of them are +2 mb7052 bipolar proms at ic 40 and 41 ive alredy purchased these and some other bits. Im wondering if there is anyone out there that could program them for me as I dont have any burning equipment. From what I understand I might need to see what version of the game I have. So while im at it should I get the roms checked and varified and reburned if any of them need it are corrupted. Any help would be great o and could the same person burn me a test rom and is the high score kit easy to do. All will be paid for lock stock the lot thanks again guys kiels202018-04-28 21:49:56
martin8or
144CR
You're going to have to find a compatible part number and then read off these proms and program/use the compatible part instead. No one seems to have any info about this mb7052 part number and I don't know of any programmers that support it.
Macro
2,016CR
It does seem to be a part that not many programmers support, unfortunately, compatible for bipolar proms seem to mean 'read compatible', they all seem to use different programming algorithms.
you would be better off with 82S129 since they are more common and supported by more programmers
but bipolar proms are write once and expensive - so not many people are going to want to volunteer to program them for you
Mitchell Gant
888CR
I'm fairly local to you, over in Chesterfield and have a Dataman 48UXP programmer that can do some PROMs. It won't do MB7052s though. It will do 82S129 or 74S287 which are compatible PROMs I believe.
What PROMs have you bought exactly? Part number printed on the chip I mean.
I'm happy to check your EPROMs for you, and burn the PROMs if you do have either of the 2 types I listed above.
kiels20
125CR
Thanks guys for all the help. I got the board and just made a list of the parts I needed looking at what other people had used. I ordered 2 mb7052 that are listed new I didnt know of equivelents or the trouble I would have with these. So I will need ether 2 82s129 or 2 74s287 to program or ask ace if I can take his offer up and try and burn me what I already have and mitchel gant your not far at all if I could send you my roms and at least get one job off the list or if I decide to buy the equivelent parts ill send you everything. As for the burning or the bipolar proms am I correct that I need to know what version of the game I have before I program these. Thanks for all the help guys really appriciate this
kiels20
125CR
Hi guys. Back with the phoenix pcb. After some work with the so kind mitchel gant checking my roms and some other bits and bobs here is were im at. After a good clean a full recap replaced d2 and d3 they were broken off nearly and replaced c2 that was totaly missing replaced a couple of over sized sockets some repairs of past repairs ive finally got is back in my machine to find this.
After I turn it on I get lots of sounds playing even the music is stuck on a loop and for a few seconds the garbage flickers and jumbles about and then its freezes. Looking with a logic probe I have clock and the reset it high it doesnt watchdog the data and address lines are active and then everything just stops like the game has frozen but it doesnt reset. This will be a first for me im thinking of checking the roms again and maybe changing the 8085 cpu or if anyone can think of anything before I do it or any help at all would be great thanks guys for all the help. O and the mb7052 are not inplace having a look with mitchel gant and it looks like I already have some sort of prom devive fitted instead of the 2xmb7052 all colours seem to be there but this isnt on the schematics
kiels202018-03-18 09:52:09
Mitchell Gant
888CR
Hi Kiel,
Looks to me like some previous owner has hacked the reset circuit by removing C2 and adding that yellow wire for some sort of external reset, maybe from a tampering switch or tilt switch. I'd remove that yellow wire now that you've replaced C2 back to the original circuit.
Then logic probe on 8085 pin 36, RESET IN and double check it's high all the time game is powered.
What does the Phillmurr test ROM screen show?
kiels20
125CR
Thanks for the help neil
I desoldered the yellow wire and there is no change but yes it does look like it was used for some sort of reset button or something. Pin 36 is still high all the time even when everything freezes. As for the test rom screen I get this its just the same as having the normal roms inplace
i did turn it on once and it got this far before freezing again. Could it be on of the 2114 ram at all ? Thanks for any help guys
kiels202018-03-19 20:03:39
philmurr
48 (100%)
2,378CR
Is the reset line actually working? Should go low on power up then high a short time later. May be worth increasing value of C2 to extend the reset pulse length.
Next up is check the data and address lines, see if they’re all pulsing away.
The 8085 is a pain to troubleshoot because of its shared data and address lines and supporting logic so you need to check the basics first.
kiels20
125CR
Thanks for the help
I did check with the logic prob what the reset did on power up and you are correct it does go lo the hi only for a split second. as for the address and data lines they pulse away for as long as the board holds out before everything just stops. Sometimes the board will wig out for 30 seconds or so giving me different screens of garbage and the freezes on the garbage screen of its choice. It might be worth a try with the cap I guess and ill have a look at some of the address and data logic in the mean time or anything else that might come to mind thanks again everyone
kiels20
125CR
Sat down and had another look at the schematics today and figured I would look at a few ic`s. I looked at ic 1-2-17-10-33. I got to ic 10 an ls138 and it failed the test so I replaced ic 10 and now I get this
It seems to boot with some garbage on screen and the wigs out and freezes on a black screen with bits of garbage on but and it doesnt like to be coined up ether that really upsets it but a big step forward for someone with little knowledge. Thanks for all the help guys any last tips would be great thanks again
kiels20
125CR
Thanks neil
But nothing much really ill get a picture up tomorrow and maybe phill can make something out of it. Ive got to put some ic's back on that I just thought I would try but they were fine but yes thanks neil for the encouragement
kiels20
125CR
Got the chips soldered back in and fitted the test rom and this is what I have.
Im going to keep at it and check anything that looks strange to me (lol most of it looks strange) but one thing I have noticed is that when it does stop being silly and it goes to the phoenix screen and the word phoenix scrolls on line by line and the the bird appears. there is a little bit of garbage on the screen that disappears when the word phoenix is getting written to the screen on the line that is scrolling on the screen. From what ive read and watched on the internet the forground abjects are different to the background objects like two layers on top of each other and I think I have a problem in the fourground maybe like it isnt clearing ram properly. Now if you can follow that and get what im blabbing on about please put me straight thanks for any help guys
kiels20
125CR
Well after a few weeks of not been able to have a look at this I finaly got round to it. I ended up sat with the schematics and my logic probe and just had a probe around. I came across a 74ls00 at ic39 with a quad 2 input nandgate with a dead output. I pulled it and it tested bad. Replaced it and now I have a working phoenix board
After I had calmed down i thought I would check if it played ok. Everything was fine untill I tried the shield and nothing. Back to the bench and reading up on a phoenix repair ( mikes arcade) I see he had the same issue and he pointed out that some operators to make the game harder they cut two traces on the top board (parts side) to make the game have no shield
After a quick repair of the traces the shield was back and all was working fine
Just like to thank you guys for all the help and advise. Thanks neil for the rom burning and advise on the proms that wasnt needed in the end thanks again
