Picky board
adebov
168CR
Some of you may know I'm quite new here...
On the recent barn raid I managed to get my hands on a Twin Cobra cabinet (Electrocoin midi) with a boardset.
The monitor needs a re-cap (no big deal - I can work that out and get hold of the components).
Where I'm struggling is the game board...
... It is JAMMA (and marked as such). There is an Electrocoin to JAMMA adaptor (in the form of a finger-board and an edge socket) mounted in the cab.
The board works fine on my Vogatek Supergun.
Other JAMMA boards work fine in the cab (with the Electrocoin wiring and JAMMA adaptor).
The Twin Cobra board is just dead if I put it in this cab (no display, no sound, nothing).
Put it back on the Supergun and it's fine.
Given this cab has a TC marquee and came with the board, you'd have thought it worked at one point.
Am I missing something completely stupid?
Hanty MTC9000 monitor BTW.
adebov
168CR
Ace` said:
You checked the power supply in the cab?
Did that before putting any games in.
All voltages +12, +5, -5 present and correct.
Voltage levels still maintained with the board(s) in place.
Can't think it's the PSU, otherwise other boards wouldn't work in the cab.
Next step, I suppose, is to strip everything out of the cab (PSU, monitor, Electrocoin to Jamma adaptor, most of the wiring loom), put it all on the test bench, so I can more easily get to things.
adebov2013-08-10 19:03:16
Ace`
PlanB contributor #1
40 (100%)
4,029CR
Are you measuring at the psu or board? the +5v can drop quite a bit by the time it gets to the board and cause the game to not run.
ben76
Hunts Spies
1,136CR
That ^^^^
- Ben
adebov
168CR
Thanks; I will check.
I didn't think of this, because it's an issue which shouldn't exist in the first place (if cabinets were designed properly).
The point is there shouldn't be such a volt drop (if the loom cable sizes were big enough in the first place).
If it's a widespread problem the game industry is at fault (if this problem is common, the 5v regulator should be on the board, not in the PSU and susceptible to volt drop along too smaller conductor size).
Coming from the industrial automation & controls industry, I normally insist cables are large enough to avoid volt drops at the expected operating current (the resistance of the cable, over its length, is the only which can cause such volt drops). I foolishly (as is apparent from your comments) expected the cabinet builders to ensure the power supply cables (in the loom between the PSU and the board) would be of sufficient size.
After all; what's the point in having a regulated 5v PSU when you have to remove that regulation (by means of turning the source voltage up) so the voltage at the other end of the cable is at 5v? Doing this means you're relying, totally, on the resistance of the cable and the current consumption of the board to drop the PSU voltage (now higher than 5vdc) down to 5v at the board end.
Obviously if I find the +5v is less than 5v I'll be putting in larger cables rather than botching it by turning the PSU above 5v.
trm
2,877CR
Hi Ade,
I think it's mainly a cost (i.e. lowest
) and safety thing. If you either fed 20+v to the PCB and then regulated down the 5, 12, -5 you're increasing the unit cost of the PCB, plus increasing the complexity. Duff board with an external PSU, chuck in a new PSU. Duff board with on-board dropdown and reg, you need somebody who understands electronics.
If you did it all with linear regs on the board you'd waste electricity and generate heat which will cause premature aging, and if you did it with a SMPSU you'll have dangerous voltages in proximity to low-voltage areas. And wiring that then comes back to the CP, speakers, mech & monitor.
Although if you do have this problem, I doubt it'll be the cables unless they've suffered a hack job over their time. It's going to be poor connections either in-line with the loom Molex or the edge connector. Given where this cab has been stored I suspect you're going to find a kilo or two of various oxides on those parts.
cheers
tim
adebov
168CR
Haha, you're right about that.
OK; my cab came out of the warehouse, but it wasn't much better than the barn
Of the top of my head, I don't know the loading (on the +5v) on typical Jamma boards (obviously there'll be a lot of variation from one board to the next).
Looking at the quantity of logic ICs, I can't imagine it's less than a few amps. The +5v cable (from the PSU to the Electrocoin Jamma adaptor, and then onto the board) is probably only 0.5mm².
I'll upgrade to 1mm² - certainly preferable to winding up the PSU above 5v.
trm
2,877CR
Has it only got a single wire for the 5V? I've only seen an ElectroC loom once and it had quite possibly been chopped by then but I didn't realise it was so tiddly!
It'd certainly be interesting to get some resistance readings from your loom - PSU connector to Electrocoin, the PSU to JAMMA edge pin etc.
cheers
virtvic
The Cabaret King
21 (96%)
2,012CR
As Tim says - Are ALL the power lines wired up on the edge connector.
I remember one of my cabs didn't have one of the two -5v wired in and on one game I had no sound at all, but my other cabs played with sound.
I added the second -5v and it worked perfectly.
Maybe you're having this same problem with your 5v or 12v lines. Also check all the grounds are wired up.
adebov
168CR
I have to assume so.
I can't imagine how it would have been in a non-working state, in an arcade 20+ years ago, with missing cables everywhere (this isn't any old cab I've tried to stick in a Twin Cobra board, this cab came from the arcade with this board in it - by the apparent age of the cab, and the game, it's always been a TC cab and would have been sent back under warranty if it was missing so many cables, the game it came with couldn't run).
trm
2,877CR
Ade,
Assume nothing about the cab, wiring, anything. We've all seen the most horrendous bodges in opped cabs. It's almost as if they competed with one another. Check everything for yourself definitely.
That probably prompts a worst-of thread soon :)
adebov
168CR
The wiring seems to be pretty much intact (and not messed about), except for one cut cable which appears to be for coin 2 (so I'm ignoring that for now).
I did find the monitor adjustment pcb was plugged in one pin adrift (causing the monitor to display a single line, straight across the middle). I'm guessing it was an attempt at repair (although quite why I don't know, as the monitor seems perfectly OK apart from needing a re-cap).
My other thought was that someone had wanted to buy the cab in the past and opened the back "to make sure it's safe to switch on", doing a very quick 'move the adjustment pcb one pin out', to make it look like the monitor was borked, so he could get the cab cheaper.
adebov
168CR
OK it's definitely the board.
Power supply & wiring in the cab seem fine.
With the coin mechs connected, the 12v drops to 11.3v but the board still doesn't work even if I disconnect the coin mechs.
Voltages at the board (in the cab) are 5.29v, -5.14v and 12.2v. All grounds seem OK.
Out of the cab and I've now got the board playing up on the Supergun (I guess I was just lucky the first couple of times).
If I power on, then off, wait around 15-30s, power back on, I can occasionally get the board to spring into life.
Once it's up, it seems to stay up (although I haven't played it through to see if it's "really" up).
Power down & back on again, and it's dead again.
Seems to start maybe once every 5 or 6 attempts.
Nothing loose, top board connectors seem securely in place.
My TV is picking up something as even when the board appears dead, the TV display switches from "no source connected" to a blank screen.
Any clues? Power circuit? Dodgy diode, transistor, capacitor? Maybe the CPU?
When "dead" it doesn't even get to the RAM / CPU / SOUND test screen - just dead to the world.
When working it passes the three tests and goes on to play the game.
Not really sure where to go next.
4,058CR
That 5v is actually far too high if that's measured at the board!
Adjust it at the PSU (assuming it has an adjustment) down to 5v if you can. 5.05v at most. All measured at the board.
I really wouldn't think that would cause your problem, but you don't want it left that high any longer than you can help.
adebov
168CR
Me neither, as it's now also happening with the Supergun (unless the PC power supply is also well over 5vdc).
